I use one all the time in warm weather. Works great, but you should always drain the water out of it when you are done if you do not use for a week or two as it can crud up and rust. I have had mine since around 1977. They are perhaps the best on thin sheet metal as it will not warp the metal. I usually blast the item and then I have a big torch --the type you burn weeds with etc on a 20# LP cylinder. A 3inch flame a foot long. I heat it real fast to dry it off so it doesn't rust. The sand can then be blown off with compressed air. The advantage is you get alot of bang for the buck if you do not have a big air compressor and use a power washer anyway. You will learn that the sand bucket should be covered as it will take on water real easy. A plastic garbage can upside down over a 5 gallon bucket works well. Keep your sand uphill of your project as the air tube that goes to the 5 gallon bucket doesn't work well with water running into it. A disadvantage is you get wet, or somehow it seems that way, and a shower is well in order afterwards, so I usually group together a few projects at a time. Eye protection is a must and perhaps a little more difficult. I use a full face clear shield and a stocking hat. Another downfall is sand recovery is impossible, and a dedicated blasting site is perhaps the best. I have 6 different town bought, and homemade cabnets that reclaim the sand that I prefer to use because of the abbrasive price. None will accomidate a big tractor hood. After abbrasive is used several times it seems to loose the cutting edge I run it through the water blaster and it is gone.
