Tool Talk Discussion Forum
OT-computer?
Jiles
02-04-2007 10:45:42
When trying to view certain sights, or one page in a sight, I have problems. When I click, all I get is a small square sympol with a circle, a square and a triangle inside. This appears in the upper left of the otherwise blank page.What could be the problem?---THANKS---
Kent in KC
02-05-2007 12:14:59
 Re: OT-computer? in reply to Jiles, 02-04-2007 10:45:42
Go to Microsoft.com and click on Windows Update (free). It will bring your computer up to date with all the little snippets you need to view most types of images.
JoeK(WI)
02-04-2007 22:24:33
Sounds like you may be missing some codes for image decoding.That icon you describe is usually a symbol for an image the computer does not understand how to display.Make sure your programs are up to date.Might also try downloading a freebie called Irfanview and just let it run in background.It's a troubled free great lil imaging program that will decode most anything and also allows you to do a little tweaking of images on your computer.
Jiles
02-05-2007 09:42:20
 Re: OT-computer? in reply to JoeK(WI), 02-04-2007 22:24:33
THANKS---I will check that out.
