The link below will take you directly to a page on the Microsoft web site that will explain how to set up multiple boot. I assume you're running Windows. Like Gerald, I've run multiple boot in the past, but only with Linux, O/S2, and DOS. The current Linux boot loader, GRUB, does an excellent job of booting multiple operating systems, but I suspect any Windows install will try to wipe it out. Generally speaking, you can only set up one hard drive in your BIOS as the boot device. Even if you can set up two boot devices, you would have to go into BIOS and change your boot order around every time you want to switch drives. That's entirely too much aggravation. What you need is a boot loader. The boot loader is a small program that tells the computer which disk partition to boot to. Typically all of your partitions are on the same physical disk. I know the Linux boot loader doesn't require all bootable partitions to be on the same physical drive, but I think the Windows boot loader might. Which means you will probably need to repartition your disk, which will usually wipe out all the data on the disk. I switched to Linux over ten years ago and never looked back. Everyone in the house has their own account, and nobody (except me) can do anything to trash the computer. No, I can't run all that Windows software, but I don't have to deal with viruses, spyware and similar problems.
