HELP On 5020 JD
Stuart
04-22-2001 06:37:06
I have 5020 jd and can't figure out the starting and charging system.i know it's 24 volt to starter and the rest of the system is 12 volt(I think).I have 2-12 volt batteries in it and a starter button that i wired in to get it to start but,none of the original (switch, button, gauges,lights) work. Wiring and everything looks good and connected properly i think. Is there a converter from 24 to 12 volt somewhere that's not working as it won't charge or do anything. Any help would be great!
Jon Hagen
04-22-2001 22:40:12
 Re: HELP On 5020 JD in reply to Stuart, 04-22-2001 06:37:06
Those old 24V JD's had a center tap ground wire on the rear battery cable that connects the two 12V batteries . This wire connects the the rear post on both batteries to the tractor frame. With this setup you can power lights and other 12V accessories from the front post of either battery to chassis ground giving 12V pos ground on one side and 12V neg ground from the other. If this ground wire is broken or corroded none of the 12V stuff will work.
