Tool Talk Discussion Forum
poulan chainsaw
jughead 2
02-02-2007 14:13:05
how does one remove the clutch from a chainsaw-I need the cog underneath to put on another saw of the same make.
Thanks
IH2444
02-03-2007 18:17:26
 Re: poulan chainsaw in reply to jughead 2, 02-02-2007 14:13:05
Sharp light taps with a small hammer and pin punch have worked well for me. Just remember it turns backwards.
jdemaris
02-02-2007 17:08:52
Usually a plastic threaded plug is used to hold the engine from turning - it's gets threaded into the sparkplug hole and puts pressure against the piston.
jhill52
02-02-2007 18:14:03
 Re: poulan chainsaw in reply to jdemaris, 02-02-2007 17:08:52
You can also stuff a piece of rope in the cylinder to stop the piston. Crude but works
nballen
02-02-2007 14:35:57
You will need to remove the (LH?) nut that holds the clutch on the end of the crankshaft. Then you should be able to (gently) tap on the clutch to loosten it and it will slide off the shaft.
You may need to use an impact wrench or hold onto other end of the shaft to loosen the nut.
Nathaniel
