Tool Talk Discussion Forum
Cleaning air compressor valves
Wardner
02-02-2007 07:48:41
What is a good solvent for cleaning the burnt varnish in a valve assembly on a piston air compressor?
I would also like to clean the external area around the valve body. The compressor is new to me and the valve body seal/gasket was not perfect. In this case, I would need something that will not damage the paint. I have tried ether and brake cleaner with little effect.
XRogerX
02-02-2007 15:10:17
 Re: Cleaning air compressor valves in reply to Wardner, 02-02-2007 07:48:41
Carb cleaner works well, if you can still find the dip type. We used to use a product called Hydroseal carb cleaner. It worked extremely well, but I doubt the formulation is the same now. Nothing beats a bead blaster though.
CENTAUR
02-02-2007 08:31:21
Try ACETONE if you have it away from the paint.ACETONE is extremely flammable.Gasoline is also very flammable.Very good to remove oil residue on the outside.Do this in the open well ventilated Or just some on a rag.Always keep in mind the possibility of what will I do in case of a FIRE.CENTAUR
