Tool Talk Discussion Forum
Mold removal from vinyl siding
Ohio Case
02-01-2007 18:35:35
Ok guys, what have you found to work the best to get rid of this creaping crud?? Its on the north side of my house
Kent in KC
02-02-2007 07:02:26
 Re: Mold removal from vinyl siding in reply to Ohio Case, 02-01-2007 18:35:35
Bleach or go to the pool store and get some Bacquacil. It is industrial strength (keyword: strength!) hydrogen peroxide. But be careful with it, it will instantly bleach your skin snowy white (and burn while it's doing it). It is far more effective at keeping a pool clean, by the way, than chlorine.
Shovelman
02-02-2007 05:58:52
We washed our house last year and tried several things, including Krud Kutter, TSP, etc., found the best combination was bleach and Wal Mart car wash. A quart of bleach and a cup of car wash to 2-1/2 or 3 gallons water worked best.
Apply with a long-handled trucker brush and rinse with a garden hose. We used a highlift which enabled us to do the whole job quickly and safely. It came out great and smells clean as well.
davejoe
02-01-2007 19:59:10
use TSP , wash from the bottom up and rinse from the top down.
john cub owner
02-01-2007 19:49:31
Out some bleach in a garden sprayer, and wet it down. let it set a few minutes, but not long enough to dry. follow with a pressure washer. loaded with some Krud Kutter (house siding cleaner) if you can find it.
Wisconsin Cowman
02-01-2007 18:47:16
A good pressure washer with hot water and some soap. Will blast that crap right off.
Glenn F.
02-02-2007 09:40:09
 Re: Mold removal from vinyl siding in reply to Wisconsin Cowman, 02-01-2007 18:47:16
A good pressure washer'll have the siding on the ground!
Glenn
NTP
02-02-2007 04:52:50
If you are going to use a pressure washer, use some caution, as using too much pressure on the underside of the siding will force water up and behind the siding,which can cause a mold problem down the line. You want to use low pressure for rinsing and spray from above so you are not forcing water under the siding. To avoid streaks when it dries, start from the bottom and work up, always keeping the cleaned area wet with the rinse water.
Rod in Smiths Falls, ON,
02-01-2007 18:46:07
I don't know about outside, but I killed off some wicked stuff inside the walls of this house I'm renovating by spraying the studs and the stone with regular 3% Hydrogen Peroxide run through my paint sprayer.
Two, one-litre applications over two days and I could work in the room without a vapour mask.
It really cleaned up the stone under a leaky chimney, as well.
On the Net I learned that Javex will mask the smell of mould, but peroxide will kill it.
lucas boy
02-02-2007 06:13:33
 Re: Mold removal from vinyl siding in reply to Rod in Smiths Falls, ON, , 02-01-2007 18:46:07
i used diluted simple green ,applied it with garden sprayer. then sprayed from a distance with pressure washer.lucas
