Tool Talk Discussion Forum
need portable heater to use in two-car garage
mech187
02-01-2007 11:45:14
What do you guys suggest to use for a portable heater to use in a two car garage on an intermittant basis when I have to work on the car in the winter. I only have one electrical outlet out there. Propane, kerosene torpedo, quartz etc? Don't need to heat up the whole garage necessarily, just keep it warm enough in the area I am working.
jwal10
02-04-2007 09:47:23
 Re: need portable heater to use in two-car garage in reply to mech187, 02-01-2007 11:45:14
I use a small 1500 watt,120 volt ceiling mount electric heater with a fan and it has its own thermastat built in the switch. Mounted it in the front of my shop at a 45 degree angle and pointed down toward where I work the most. Removed a light bulb,screwed in a plug in adapter, screwed in light bulb and plugged in heater. It doesen't take much to take the chill off when shop is insulated, I work in shirt sleeves at 55-60 degress. This shop is 24x24 welding shop, I have another wood shop 12x24 and another 24x36 truck shop, same heater in all but largest has 2 as I like the heater blowing air where I am working. The 2nd two shops I hard wired heaters in when I built them. I don't turn them off I turn them all the way down when not in there, probably 40 degrees. I find dampness is worse than cold.
MarkB_MI
02-02-2007 03:18:58
If you don't mind waiting for a half-hour or so for the garage to warm up, a kerosene heater is a good way to go. I have a 23,000 Btu/hr Dyna-Glo heater, and it does a good job of heating up my insulated 2-car garage. It's quiet, doesn't stink and is quite safe.
A torpedo heater will heat your garage faster, but they're loud, they stink, and you have a very real danger of carbon monoxide if you don't have fresh air coming in.
JMS/MN
02-01-2007 17:57:33
Another option is a sunburst heater that attaches to a 20 lb propane tank. No electricity, valve controls output.
135 Fan
02-01-2007 17:12:19
A reddy heater works great. Can burn kerosene or diesel. Even has a thermostat. Heats up fast but make sure to open a door a little to get fresh air and vent fumes. It will still keep you toasty. Propane is OK but causes a lot of moisture. Kerosene or diesel is a drier heat. Kerosene supposadly has less fumes than diesel but is a lot more expensive. Hope this helps. Dave
Ryan - WI
02-01-2007 16:36:48
I put in a natural gas unvented wall heater the fall after we bought our house. One of the smartest things I ever did. It heats up the garage well enough to work in shirt sleeves all day and I do not have to worry about gases killing me off as the heater has an O2 sensor in it.
IH2444
02-01-2007 12:18:51
How cold does it get outside where you are ? And is the garage insulated ?
mech187
02-01-2007 13:58:35
 Re: need portable heater to use in two-car garage in reply to IH2444, 02-01-2007 12:18:51
It's been getting down to around 10 degrees overnight and garage is insulated.
jhill52
02-01-2007 12:18:32
I have a kerosene torpedo heater I use when necessary. It puts out alot of heat fast to get the garage warmed up. I then turn it on and off as necessary. O.S. I made a short extension cord with a switch in the middle so I didn't have to unplug it all the time.
dds-inc
02-01-2007 13:13:03
 Re: need portable heater to use in two-car garage in reply to jhill52, 02-01-2007 12:18:32
it's prolly a good idea to unplug something that has flammable material in it.
