Tool Talk Discussion Forum
Drill press chuck
jc
01-31-2007 19:10:54
I'm not a regular on this board but I have a tool question I hope you will help me with. I have done a breif search of the archives and found good info on types and removal/replacement.
Could you name some good sources to purchase one as I have a broken jaw? Probably mail order or online. Our small town is hardware storeless. Thanks.
MikeCatthemuseum
02-01-2007 21:36:03
 Re: Drill press chuck in reply to jc, 01-31-2007 19:10:54
I'll second the Ebay suggestion. As for a brand, Jacob's. The cheaper imports are pretty likely to slip, even when tightened up. You can buy a new or like new Jacob's off Ebay for a lot less than catalog price. You can also buy rebuild kits for Jacob's chucks, so the next time you break a jaw, you can just rebuild the chuck.
chvet73
02-01-2007 08:14:29
Go Enco. When I got an old Logan lathe I got most of my tooling thru them. Great service and decent products from lower end to top quality.
Chris(WA)
02-01-2007 06:56:44
Here is a good source for all sorts of good reasonably priced drill chucks and a lot more. Great people.
jhill52
02-01-2007 05:42:35
Ebay
Joe(TX)
02-01-2007 05:15:48
Try Enco tools or MSC industrial.
Enco will be cheaper than Mcmaster Carr and has better stuff than Harbour.
msc http://www.mscdirect.com/
djm75
02-01-2007 04:42:02
also a very good source and probably the largest msc or industrial pipe and steel too.
TimV
01-31-2007 19:16:05
JC: Depending on how much you want to spend, two excellent sources are McMaster-Carr (www.mcmaster.com) and Enco (www.use-enco.com). Harbor Freight, Northern Tool and similar places also carry them, though your selection may be more limited.
