Tool Talk Discussion Forum
Ceiling fan reversing
RegoR
01-31-2007 10:36:17
Hi all,
I have an old Hunter ceiling fan that doesn't have a reversing switch. (How) can I add one?
Thanks,
Roger
Thanks
02-02-2007 06:32:53
 Re: Ceiling fan reversing in reply to RegoR, 01-31-2007 10:36:17
Gentlemen,
Thanks for the feedback & suggestions.
The fan has a heavy cast housing with an oil bath motor. Fits real well in this 84 year old house, unlike a new one would. Maybe I'm old fashion, but I guess that's why I have an old tractor too.
Roger
"fanman",
I might have tried your suggestion, but you didn't specify what gage guy wire to use and I didn't feel qualified to size it myself.
Gary from Muleshoe
02-01-2007 13:06:36
I agree with four4speed, the motor would have to be wired to run in both directions. It would be cheaper to buy a fan already set up for both directions.
four4speed
02-01-2007 11:39:51
I am not sure how your fan motor is wired, but the manufacturer may not have wired it for the reversing switch. As many AC motors are wired for only one direction, the fan motor may be the same and reversing is not an option for that motor. Good Luck.
Jerry (KS)
01-31-2007 18:21:34
Try this web site for wiring diagrams
Link
deerhound
01-31-2007 14:07:59
It may have reversable pitch blades. On an old Hunter fan I had, you just pushed the fan blade inward, toward the hub against spring pressure, then you could ratate the blade so that it would blow up instead of down. The motor always turned the same direction
Dale
fanman
01-31-2007 12:26:54
Just put a tall pedestal mount on the floor and mount it upside down ?
