Tool Talk Discussion Forum
Spring tension
Slowpoke
01-30-2007 11:08:36
Is there any way to reduce the force on an extention spring? The spring is .265 OD, .350 long without the hooks, and the wire is .017. The force is about 1 lb. It needs to be reduced to about half but I can't find any thing that small at the hardware stores. Will heating do any good or will it be damaged?
Thanks
Jerry/MT
02-01-2007 13:07:38
 Re: Spring tension in reply to Slowpoke, 01-30-2007 11:08:36
Springs have a certain "spring rate", i.e. a spring that has a rate of 1 lb per inch, will take 1 lb of force to compress/extend 1 inch. You can reduce the force of a given rate spring by reducing the ammount to compression or extention on the linkage if it has an adjustment. Otherwise you need to get a spring with a different rate.
Slowpoke
02-01-2007 23:15:07
 Re: Spring tension in reply to Jerry/MT, 02-01-2007 13:07:38
Thanks, the problem has been solved as explained below to Dan Hill.
Stumpalump
01-31-2007 06:12:00
Stretch it and cut off the extra.
kidbob
01-30-2007 20:46:53
Check for throttle return springs at an auto parts store.
CENTAUR
01-30-2007 14:01:39
I have one thats about 10mm-in length and .017 wire.It is a lite pull with a hook on both ends.I have no way to measure the tension.I will mail it to you if we can communicate. I will try.CENTAUR
Slowpoke
01-30-2007 15:02:13
 Re: Spring tension in reply to CENTAUR, 01-30-2007 14:01:39
Thanks for the offer, I'll keep it in mind. (Your spring is .394 @ 10mm.) The spring, (about 21 coils, .365 long coil) is used to return the shift lever indicator to Park. The cable to the indicator broke. The dealer cost is $32.50 so I used 27lb stainless steel fishing cable and crimpers making a loop on each end. The cable rides inside a plastic tube, pulls on the indicator arm and the spring pulls the arm opposite keeping the cable tight. There's quite a pull on the mounting posts when the spring is stretched to D1. I'd like to reduce some of the tension to prevent the mounting posts from breaking off. The distance between posts is about 1/8" longer than the spring when it's at rest. Maybe I'll just have to use it as is and hope for the best.
Dan hill
01-30-2007 15:32:26
 Re: Spring tension in reply to Slowpoke, 01-30-2007 15:02:13
Take the spring down to the hardware store select one with less tension.Make the cable a bit longer or add a fish line swivel to the cable.
Slowpoke
01-31-2007 01:04:21
 Re: Spring tension in reply to Dan hill, 01-30-2007 15:32:26
Nothing available that small at the store. I found a longer spring about half the diameter and cut it to the same length as the original. I hung the springs from a rod and put identical weights on both. The new spring stretched about 50% longer. It works much easier than the original when installed in the indicator unit. So now I can put the instrument panel back together and get on with life. By the way, it all has to come out to change any burned out bulbs.
ken in texas
01-30-2007 12:17:46
Usually if you heat it enough to soffen it , it will lose it's temper and will be useless.Might try aumotive parts store,some carbs might use the type of spring you are looking for.
