Tool Talk Discussion Forum
Welder to LP Gas
patsublett
01-29-2007 15:27:53
I have a 20 HP welder that I use for a standby generator. I would like to convert it to LP gas. Does any body have any advice.
Tim Casbolt
01-30-2007 15:22:50
 Re: Welder to LP Gas in reply to patsublett, 01-29-2007 15:27:53
Try these guys: >Link
Converted>Link my 4000 watt Onan, and would never go back to gasoline. No more float problems, no more stale fuel, oil stays clean forever, always starts right up, etc., etc., etc.
ScottP
01-30-2007 11:52:58
You will lose 15 percent of the HP on propane.
Also make sure you use ash-less oil. Unless you like to replace valves. The coke build-up is real bad with the ash. I use delo-400 30w in mine, works well. Buy a propane carb, don't use a spud in kit,
they are nothing but one big pain in the donkey.
Scott
Garry in OK
01-29-2007 22:15:06
Try propane-generators dot com. They seem to have quite a selection and are easy to deal with. I run a Miller Bobcat with a Kohler motor on propane. Works great so far.
Glen in TX
01-29-2007 15:40:30
If you have a larger LP tank it can just run off vapor a long time for that size of air cooled engine. Small engine shop should show a LP setup for it in parts catalog. If not check with Impco or local LP dealer. You'll need the gas regulated to it of course and may can just insert a feed tube into the carb on it in the correct place in middle of feed area.
