Tool Talk Discussion Forum
What to buy?
Vern
01-29-2007 07:07:59
I want to buy a self-propelled, walk behind, rear bagger lawn mower for our Church. The lawn is mostly flat with one gradual sloped area.
Also, the lawn is made up of several small areas so there is quite a bit of turning around & a rider is overkill.
Which, in your opinion, is better, a rear wheel drive or a front wheel drive
Throop
01-31-2007 09:56:30
 Re: What to buy? in reply to Vern, 01-29-2007 07:07:59
I agree with JT, I have a Toro, starts on first pull every time, variable speed rear wheel drive which goes faster as you walk faster. Had it 7 seasons now, wouldnt be without it.
hlc
01-30-2007 11:42:07
I have owned and worked on and used in grass cutting several including Snapper, Toro, Honda,Craftsman and several others. I would select Honda in about 5 seconds. Actually I don"t have much experience working on the Honda. Never had too. You can get one that will bag or mulch and only use the bag if necessary. I also prefer rear wheel drive. Although the front drive can possibly get around things a little better it does not compare when pulling up hills or working on slopes. Rear wheel drive machines don"t go around spinning all the time on the grass.
Vern
01-30-2007 13:37:33
 Re: What to buy? in reply to hlc, 01-30-2007 11:42:07
Thanks for all the responses. I think I'll go with the rear drive.
Vern
Oldmax
01-30-2007 05:21:16
Don't buy a mulcher mower unless you are going to mow every 3 or 4 days .
TomTX
01-30-2007 02:02:00
Honda, with the infinetly variable hydrostatic rear wheel drive. I use the mulching one. Has 2 blades, cuts grass into VERY small pieces and blows it down into the grass. They are expensive, but will last forever, start easy, easy to handle. Tom
504-1
01-29-2007 19:59:37
Rear wheel drive, I have never talked to anybody that has bought a second front drive. RWD you push down on the handle and go around the turn from drive you push the mower
MikeCatthemuseum
01-29-2007 14:54:34
Having spent a few years of my younger life chasing a mower around for a living, as well as repairing them for the same company, go with a rear drive and I'll suggest a Snapper if you can afford to spend a bit more money than a Wal-Mart special. The Snappers are easier to work on than many of the commercial makes, lighter, less complicated, and have a far wider range of speeds that are more easily adjusted.
Toros have the shift mechanism set up so that it can't be operated without stopping and shutting down (to prevent employees from downshifting when the boss isn't looking). The Snapper uses the same friction drive disc as their riders so you can change speeds under power. The discs last forever, even under heavy commercial use, same with the drive belt (and those are really the only parts that wear in the drive). Additionally, the Snappers have a differential so you can turn without dropping out of drive or lifting the wheels.
Another great feature of the Snapper is that hi-lift deck. You can also use the mower in leaf season instead of raking. It'll bag leaves like nobody's business. We basically ran them year-round in the lawn maint business for this reason.
I visited a friend about a year ago and saw he had one of these Snapper self propels with a 4hp Wisconsin-Teledyne 4.5hp two stroke on it sitting in his garage. I hadn't seen one since I used them in lawn service and commented on it. "I asked you in about 1987 what the best self propel lawnmower around was, this is what you told me to buy," he said. He has used it every year since with not a single glitch.
Mike M
01-29-2007 12:46:39
I have an older JD 14SB this is the silver colored ones. I really like it as the kawaski engine is smooth and the rear drive works good and has 5 speeds you can adjust. Having a blade brake clutch is also nice as you can start up the engine and self propell around over gravel drives and such without the blades turning.
One draw back I see right away with a front drive is if you are going to bag as the bag fills your going to loose weight on the front. Dad runs front drive old Toro mowers I hate that front drive as it wears out the tires fast as they are always spinning and you got to lift up the mower to go anywhere.
neblinc
01-29-2007 11:46:20
I am thinking a front wheel drive is the way to go. When making a turn you just push down and raise the front wheels, then go to the next pass.
Randy
JT
01-29-2007 07:20:29
If you want a real good walk mower, buy a Toro Super Recycler, if you can afford it, They sell for 499.00 and they are by far the best mower I have ever had my hands on. If you cannot afford the SR, by the standard recycler, they sell for 369.00. the cheaper one has a steel deck, with stamped, non servicabel rear wheel adjsuters with a 2 year warranty. The SR has a magnesium deck, servicable rear wheel adjusters with a 5 year warranty.
1936
01-29-2007 07:12:26
Rear wheel for hill type lawns or any lawns. Have a Scott by JD bought used real nice.
