Tool Talk Discussion Forum
black and decker cordless drills
Delbert
01-28-2007 17:54:38
Are 18 volt black and decker drills any good? Does anyone own a 18 volt chicago brand from harbor frieght? Thanks for your input Delbert.
Rod in Smiths Falls, ON,
01-30-2007 14:00:49
 Re: black and decker cordless drills in reply to Delbert, 01-28-2007 17:54:38
I have had a factory rebuilt 12V Black and Decker Industrial for years now and am still on the same battery. It has been a very good cordless drill, able to handle more and heavier work than most others.
BobOHIO
01-29-2007 19:05:31
I have the BD 18 volt drill and have had good luck with it so far. It has been a good drill for me at home.
NE IA Dave
01-29-2007 17:24:09
I have been using them Dewalts for years, starting from the 9.6, then 14.4 then 18 volt --all Dewalts, not B & D. We used the saws, drills, flashlight, & sawzalls. I loved them untill my two sons and my brother, all seperate carpender or drywall contractors introduced me to the Craftsmans. I was pretty bullheaded because the Dewalts seemed to be better balanced. I kept the Dewalts and just bought a few Craftsmans. The crew guys all left my Dewalts sit and grabbed the Craftsmans, so I tried a few more Craftsmans, and now I would not think of looking back. I now have mostly all Craftsmans but (like the Dewalts) intend on replacment every year to eighteen Months, with the drills. The Dewalts did have a occasional bad chuck, switch, charger or battery, but they did pretty good.
Now however, Dewalt can stick there high prices way way up there where the sun don't shine. I watch the Sears specials and will have a Craftsman drill, two batteries, and charger for the price of a Dewalt replacment battery plus around $20.00.
A coworker (he furnishes a few basic tools on his own) and isn't the sharpest tool in the shed has to have Makita because he can't stand to throw away a working drill that just needs two batteries, and a new charger. Yea his head is way up his rear, these things are throw aways, you just can't marry them. He is the object of alot of crew jokes, but the guys are trying to help him manage his money without slaping him upside the head.
I should mention we have had two Dewalts chargers catch fire, --probably overfused---so after the second one we always put all the chargers inside a military amo box, it holds all eight chargers at one time, so we did not worry about a project burning down.
If you purchase a Dewalt with the stem on the battery, you can watch for Black and Decker 18V batteries in the bargin bins. All you have to do is cut off the 1/4" x 1/4" plastic keyway with a sharp utility knife and they will interchange. One is left side the other is dead center.
The Dewalts did not do any better in our crews daily crash tests, the trigger spring is the hard part to find in the broken parts. We are very abusive with the drills, we work --up there-- most of the time and for the most part I do not care unless it is total carlessness or if the indavidual has had bad habits pointed out.
NE IA Dave
msb
01-29-2007 10:06:20
If you can find one, get a 24 volt B&D.I got one a year ago and have only had to recharge it once is a year of fairly heavy use.Its a very powerful drill.
L K Marble
01-29-2007 09:37:44
I have used two Harbor freight 18 volt drills. You can't beat them for the price. I put up a 24'X54' metal building with one of them and still using it. Prefer the Chicago (Yellow) one over the Central tool (Blue) one. Just as others have said If you drop them be ready to pick up lots of pieces. Finally tore the gears out of one. A good charger and extra battery is a must. 19.2 Volt is even better although a bit heavy to use all day.
1936
01-29-2007 07:37:49
Have an 18 volt B & D saw. Ripped long ways untold 100's of feet of treated 2 by lumber. The only hick up is the charger and bad batteries. Burn up charge when trying to charge a dead one. Charge only 2 minutes and test to see if up to or above correct volt for a good one if not discard bad battery. Never leave on charge for more than hour for good batteries. No charge for the free advice that I paid for.
alg
01-29-2007 05:40:50
The Haror freight drills are o.k. for the price.Just don't drop it ,you will be picking up the pieces.BTDT.
ArkanDan
01-29-2007 04:25:50
I've got two of the 18v B&D drills. They are great! The charge lasts forever and they have an abundance of power. They are light and versatile. They are built a bit light and so if dropped from high up they will break. I broke one from a drop of 8' to the concrete floor. Used epoxy to put it back together. Still going strong. Have been using them on a house building project that started last August. Paid $60 each for them at the B&D outlet store. That was with the charger, case, and two batteries. Highly recommend.
Randy in PA
01-28-2007 20:54:29
I just bought a new 18v makita with the new lithium battery. $200 bucks from home depot. This is the homeowner black and white version, not the blue and black version. I cannot believe this drill. It about killed me to spend the $200 bucks but it is worth every penny. This drill is supposed to drive 100 3" screws all the way into a board with no pilot with power to spare. And the battery recharges in 15 min.
Rockyhawaii
01-28-2007 20:23:53
I have the 18 volt model and it is nowhere as good as my old 9.6 volt and 12 volt Makitas. I also had the 14.4 volt model until yesterday when it crapped the bed before I used it three times or so. A small plastic piece broke off inside and I threw the drill away because replacement parts are apparently not made. It will be cheaper and less headache to simply buy another drill.
