Tool Talk Discussion Forum
Sanborn Compressor Reliability?
Kerwin
01-28-2007 15:34:04
Anyone have experience with Sanborn compressors, that are now made by Coleman? There's a 60-gallon model (4.7 running HP, 22 amp motor, 230V) that I saw at Menards that looks like it will fit my needs, but want to make sure that they aren't lemons to begin with.
The compressor is a cast iron 3-cylinder type with the cylinders offset at 90 degree angles to each other. How reliable is this setup?
Any thoughts on these compressors is appreciated! Thanks for the help.
MikeCatthemuseum
01-29-2007 14:25:23
 Re: Sanborn Compressor Reliability? in reply to Kerwin, 01-28-2007 15:34:04
I have one of the Sanborn oilless I think RayP is referring to. Same problem, had the pressure switch go out (pressure switch still works, but you have to unplug it, as you can't turn it off) and then the crappy plastic onboard regulator blew up. Neither part is available in any way, shape, or form, so I just had to live with it as best as possible. I'd be real hesitant to buy for that reason alone.
As for the one you are looking at, forget whatever the motor rating says. Motor HP is a useless way to buy an air compressor. Look at the delivery in cfm at the pressure the tools you use operate at, then look at the consumption of those tools. If the compressor can't deliver at least 1.5 times the consumption, you'll be sitting around waiting for it to catch up about 50 minutes out of every hour you are working. Low duty cycle tools like impact wrenches are not so big a deal, but a sandblaster, DA sander, etc... running at 80 or 90% duty cycle will test a compressors mettle.
Most of the Lowe's, HD, Sears 60-80 gal tank compressors I have seen are in reality barely 3 hp (if you are lucky). They will have a motor rated at "7 peak hp", but will deliver about 12-14cfm at 90psi (about 1 1/2 real hp). They have learned that you can put a pee-wee sized pump with a peak rated (severely overrated) 3450rpm motor up high on a big tank with lots of plastic covering and folks think it's a big compressor.
RayP(MI)
01-29-2007 17:30:23
 Re: Sanborn Compressor Reliability? in reply to MikeCatthemuseum, 01-29-2007 14:25:23
Mike, mine is actually a two cylinder oil-filled crankcase type. Came wired for 110v. Wasn't worth a darn till I converted it to 220v. Required a new pressure switch with dual poles for 220v. On 220v it starts and runs fine - on 110v it wouldn't start easily, and constantly blew fuses, etc. Supposed to be a 2hp motor. Then I had a cylinder head self destruct, destroying the head and reed valves. That was a while ago, and was able to get a new one from Sanborn.... Had another head-reed valve problem, and couldn't get new head fron Coleman. Was able to fabricate parts using scraps of aluminum, and Dremmel tool to repair head this time. It fails, and there's going to be a new compressor on site. And it Ain't gonna be Coleman!
MikeCatthemuseum
01-29-2007 19:14:06
 Re: Sanborn Compressor Reliability? in reply to RayP(MI), 01-29-2007 17:30:23
Ah, you actually have a better one than this thing I have, but I have to admit it has lasted forever other than the above problems. I bought it used about 94 or so and it still runs.
BTW, in my previous post I meant to say that 12-14cfm is about 2 1/2hp real hp, not 1 1/2.
RayP(MI)
01-28-2007 16:04:04
I have a Sanborn, made before Coleman bought them out. Mine is no great shakes, and Coleman doesn"t carry parts for it - obsolete they say. I won"t buy another!
