Tool Talk Discussion Forum
Where to buy 2 bronze bushings?
Gwiz
01-28-2007 06:48:48
Mac-Master Carr has every size except the one I need. Who else might have bronze bushings with inside diameter of 2" and outside diameter of 2-1/8"? The o.d. of 2 1/8" is what Mac-Master is missing. Thanks,
James
J.T.L.
01-28-2007 18:08:29
 Re: Where to buy 2 bronze bushings? in reply to Gwiz, 01-28-2007 06:48:48
Check this web page out and see if something on it will suit yopur needs. Maybe contact them for specs that will match your needs.
Link
John
Gwiz
01-29-2007 15:04:11
 They have some! in reply to J.T.L., 01-28-2007 18:08:29
They have 2 my size. I have e-mailed them for a price on one and to see if they sell retail.
Thanks for your help.
James
NC wayne
01-28-2007 16:10:12
Like some of the others have said that sounds like a thin wall for a bronze bushing of that size. I know we're old fashioned sometimes when it comes to things like this but you ought to seriously loo at some of their "plastic" bushings to use in it's place. Often they have higher load ratings than the bronze as well as being able to run dry. If not a plastic one then for a bushing that size look at the shell bushings that have an outer steel shell with a bushing material on the inside, like a king pin bushing. In some cases either choice just might be better than what was there origionally.
Sam Mills
01-28-2007 14:01:59
Try This link or call 800-431-1962in fresno CA. Talk to Mr Matt Cole. Link
Sam Mills
01-28-2007 14:00:53
Midwest redneck
01-28-2007 12:25:54
Are you sure that is a 1/16" wall size on those bushings. (verify dimensions)
Midwest redneck
01-28-2007 08:22:08
I will make them for you if you want. I am serious. Write back and let me know.
Gwiz
01-28-2007 17:37:32
 Re: Where to buy 2 bronze bushings? in reply to Midwest redneck, 01-28-2007 08:22:08
My problem is this is not something I want to spend much money on. How would you do it, and how much would it cost?
These were the wheel bushings from an old Ezee Flow fertilizer spreader. Not worth much, but would be handy to get going.
Thanks for your input.
James
midwest redneck
01-29-2007 02:34:34
 Re: Where to buy 2 bronze bushings? in reply to Gwiz, 01-28-2007 17:37:32
I would make the bushings on a machine shop lathe, which I have 2 at work.
Gwiz
01-29-2007 14:30:01
 Re: Where to buy 2 bronze bushings? in reply to midwest redneck, 01-29-2007 02:34:34
Starting from scratch, or turning down some premade bushings? For instance, McMaster has some with OD of 2-3/16 for $17+. From the get go, I would have $70 in them this way, and that's about all I would consider spending on this thing before discarding it.
Thanks
James
Gwiz
01-29-2007 15:07:13
 Re: Where to buy 2 bronze bushings? in reply to Gwiz, 01-29-2007 14:30:01
Hold on, Applied has some that should work. The teflon ones are less than $10 if they will work and they will sell retail. Thanks for your offer, but this will be the simplest route if I can get these bought.
James
jdemaris
01-28-2007 08:08:56
I've seen them in nylon, plastic, or teflon, but not in bronze. That would be a 1/16" wall thickness - seems pretty flimsy for a bronze bushing. Any catalogs I have - only show them in 1/8" wall thickness once they get bigger than 1 1/8" i.d. Why not just get a standard 2" i.d. X 2 1/4" o.d. bushing and grind down the o.d.?
fixerupper
01-28-2007 08:08:46
That's pretty thin walled. Maybe a heavy machinery supply would have something. I'm thinking maybe some machinery with large hyd cylinders might have a bushing like that for the pivot pins. Maybe a pivot pin bushing for the front axle of a larger tractor might have those dimensions. If nothing else works I suppose a 2 1/8" OD bushing with a thicker wall could be reamed out. Someone else on the board probably knows of a better place. Jim
