Tool Talk Discussion Forum
Filling Disposable propane bottles
Cooker.308
01-28-2007 06:29:31
Anyone have any experience with the fitting, Cabelas sells for filling your disposable propane bottles off a 20lb. tank? Thanks in advance Cooker.
supergrumpy
01-28-2007 11:35:58
 Re: Filling Disposable propane bottles in reply to Cooker.308, 01-28-2007 06:29:31
takes a while to fill, have the 20lb tipped over so you are moving liquid rather than gas
only pressure you have is whats inside the 20lb tank rather than the pump pressure you usually have, I used to stop at 1/2 full
also, tip 20lb tank to the side rather tna upside down, sometimes there is debris inside the big tank that plugs the small openings
oh, put your cigarette out first.
jwal10
01-28-2007 09:34:09
I have done it for 20 yrs no problem. Had to buy a new one when they changed fitting on 20 lb cylinder. Use a lot of disposable tanks on torches, easy to handle. changed most everthing else to 20 lb cylinders.....James
mj
01-28-2007 07:27:47
Yeah, works good..... ..just follow the "structions.
