Tool Talk Discussion Forum
air hammer
jackbrit
01-24-2007 14:41:39
I would like to buy an air hammer for doing car and truck (1 ton) suspension repair. I have used a mac 650 and liked it. Is there a big difference between the snap on, mac? Does ingersoll rand and chicago pneumatic make a good one and what model?
thanks
jack
Cliff Neubauer
01-24-2007 19:46:16
 Re: air hammer in reply to jackbrit, 01-24-2007 14:41:39
I bought a Snap On PH3050 (the biggest Snap On model) on ebay last year and it wasn't cheap but it hits really hard.
AIR HAMMER
01-24-2007 17:41:05
The secret is for you to buy a long stroke.low cyclic rate which you will need for the kind of work you intend to do.A short,high speed stroke is very good for cutting sheet metal like a body shop man would use.So get a long barrel and it will hit much harder.You do not have to have a well known name. AIR HAMMER
mph
01-24-2007 17:24:22
IR person myself, last one is a 2131 no regrets.
Don L C
01-24-2007 17:18:59
..... I am using a Chicago from Harber Fraight, its about 6 yrs. old..... .I keep it clean and well oiled....that is the secret....I think I paid about $30....
Phil9N3667
01-24-2007 17:16:11
In regards to who makes the better unit, I had a Snap-On heavy duty model that lasted over 25 years before the housing cracked around the handle end!! Mac also mkes a good unit as do IR and CP. Matco also sells a good air hammer. Your best bet is to get one from someone/supplier who can service it for you if you"re going to be using it a lot. Keep it well lubricated ( a few drops of air tool oil every day of use) and to make it convenient, put a quick change coupler on it. Oh and wear EYE and EAR protection or you"ll end up deaf as a post like me! Good luck.
