Tool Talk Discussion Forum
Clothes Dryer propane or Nat. Gas
Gene P
01-23-2007 21:07:23
How can I tell if the dryer I have been given is set up for propane or natural gas.
I don't want a fire sale next week.
MarkB_MI
01-25-2007 03:57:22
 Re: Clothes Dryer propane or Nat. Gas in reply to Gene P, 01-23-2007 21:07:23
I assume you're on propane, since running a gas appliance on propane is a bigger problem than running a propane appliance on gas. (The former is going to run too hot, while the latter will run too cold.) I suggest you check the dryer model number and Btu rating, then call your propane supplier. I think they can tell you the proper size orifice for your dryer, then you can just pull out the burner and verify you have the right orifice. I imagine the appliance manufacturer can tell you this information as well.
If you can't get anyone to tell you the proper orifice size for your fuel, just order a conversion kit and be done with it. They're not that expensive.
Paul Janke
01-24-2007 05:31:56
If you have both orifices, the one with the bigger hole is for natural gas. It is the one which runs at a lower pressure. The parts for the gas not in use should be there in a little sack if memory is correct. Please double check what I say, it has been fifteen years since I have had anything to do with that stuff.
R Bedell
01-24-2007 03:38:28
All gas dryers come from the Factory set up for NAT gas. "IF" a responsible person converted the dryer to LP, there should and normally be affixed to the Burner Assembly, a sticker stating so.
