Tool Talk Discussion Forum
Snowmobile help
Gordon schafer
01-23-2007 17:19:07
I have a 1980 arctic cat jag and was wondering if anyone knows what the problem is. The snowmobile stalls out when I let up on the gas.
Wisconsin Cowman
01-25-2007 18:00:47
 Re: Snowmobile help in reply to Gordon schafer, 01-23-2007 17:19:07
Sorry can"t really help you, but in my area of Wisconsin people call them $hitty kitties.
traper
01-24-2007 18:39:27
I have two 81 440 jags in the stable of cats we have 15 cats from 1969 to 1988 but for runing through woods ill take the 81 jag every time.
Brian in NY
01-24-2007 13:03:54
Well it could be a number of carb problems...
can't recall if those had a float carb or a diapraghm carb...but a hardended diapraghm can be a real problem, as well as general gumming up of the carb if it's a float type.
traper
01-23-2007 18:03:53
Look at trottle were it meets handle see if there is a little plunger there? I think you have to shorten cable to close plunger.One other thing if it is boging at low speed on top of carb there is a brass plug with screw slot and hole in middle take it out clean out hole on inside.If on trail take out plug suck dirt out re install. Belt dust gets in it common problem.
jhill52
01-24-2007 04:25:00
 Re: Snowmobile help in reply to traper, 01-23-2007 18:03:53
I forgot about that. Arctic Cats have a throttle saftey switch. You cannot have any slack in the throttle cable or it will not idle. Adjust that and it will curwe it.
jhill52
01-23-2007 18:01:22
If it starts hard also it could be a side seal.
