Tool Talk Discussion Forum
buildin a pressure washer?
JJP
01-22-2007 18:08:55
I have an older Briggs and Stratton 5 hp. vertical shaft lawn mower engine. I am thinking about the possibliities for this engine, and one would be a pressure washer.
I was curious if anyone has built, or looked into the idea of building a pressure washer.
I haven"t looked at pumps or attachments, so I don"t know if this is even economically worthwhile...of course, that has never stopped me before!
Ant ideas would be appreciated- thanks!
buickanddeere
01-23-2007 19:37:33
 Re: buildin a pressure washer? in reply to JJP, 01-22-2007 18:08:55
You can purchase an entire new high pressure washer with warrenty. For less than the price of purchasing all the bits and pieces and building one.
jjp
01-23-2007 06:14:23
Thanks for the advice...sounds like my next step is to go to NorthernTool.
Uncle Ernie
01-22-2007 20:27:28
That little 5 hp would not have enough snoose to run much of a pump.Hold out till you have at least 10 hp to build a pressure washer.
Hermit
01-22-2007 18:27:13
You might want to check out the Northern Tool catalog in the pressure washer accessories section. It has all the parts you might need to make a pressure washer. Have fun.
www.northerntool.com
NC Wayne
01-22-2007 18:17:31
Dad and I built one several years back using a 11HP Honda we had laying around. Don't remember what one that size was going for back them but I do remember the cost of the pump alone was way less than the cost of a whole unit. In our case we used a 3000 psi pump and we made a framework for everything that allowed us to pick it up with the cranes on our service truck. We also mounted a large sediment filter, to the cart, on the pump supply line so we could supply the water to it out of a sediment pond using a small gas powered pump. Like I said don't remember the cost of a complete unit but doing it this way saved us alot of money and we got a unit that we can load easily for use in the field. Good luck.
Catskill Pete
01-22-2007 21:21:29
 Re: buildin a pressure washer? in reply to NC Wayne, 01-22-2007 18:17:31
Yup works just fine, within limits. I built exactly what you are talking about a few years ago. My electric pump died on me for about the third time,[last electric pump I"ll own],and I had a nearly new 5hp Briggs sitting around. So I got a Gp pump from Northern and built one. I still have it and use it once in a while, also loan it to friends. Not as nice as the as the 10 horse I since bought, but it gets the job done just not as fast as the bigger one. However by the time you buy the pump,hose,wand, and connectors plus build or buy a cart, I"m not sure you are going to save any money. But it does work.
