Tool Talk Discussion Forum
Still working on....
Slowpoke
01-21-2007 15:11:39
the 65amp alternator for my "86 F250. Mine is totaly fried. A friend gave me a brand new one that"s rated at 80amps. Problem is I can"t get the nut off to change pulleys. The alternator is out of the truck. I made a sort of wrench out of rebar to hold the fan and used a breaker bar but the nut holds fast. My air compressor is not working so I can"t use an impact gun. Is the gun my only hope? What is the right way to hold the pulley and remove the nut???
Thanks
mph
01-21-2007 21:47:19
 Re: Still working on.... in reply to Slowpoke, 01-21-2007 15:11:39
I have an old IR elctric impact, not much compared to the air but have used it on such and will do what you want. I have many times in the past befor the shop and goodies that I have now. Even the electric as old as it is still does 240 ftlbls. not bad for over 40 years old tool!
Slowpoke
01-21-2007 22:25:53
 Re: Still working on.... in reply to mph, 01-21-2007 21:47:19
mph,
Good idea! You made me remember that I have one out in the back shed. I haven't used it in years but I'll give it a try....thanks.
old
01-21-2007 15:38:39
Most alternators have an allen wrench hole in the shaft for holding it, then you use a open end or box end wrench on the nut. Useing a hammer on the wrench will help since you can't use air.
Slowpoke
01-23-2007 00:23:09
 Re: Still working on.... in reply to old, 01-21-2007 15:38:39
Hey, old, no hole in this one! I tried my Millers Falls electric impact with no results. So I used a friends air compressor and my B&D impact to remove the nut. I couldn't believe how easy it came off just holding the pulley with my hand.
