Tool Talk Discussion Forum
Window replacement
PAGlenn
01-21-2007 07:41:26
I need to replace the windows in the office of my pole garage. The building is located 75ft. from
the road. What is the best sound proof window to use. Cost is no problem. Only two windows need to be replaced.
CalJim
01-21-2007 22:05:49
 Re: Window replacement in reply to PAGlenn, 01-21-2007 07:41:26
Turtle is right you need LAMINATED glass
in the dual pane units. Wood is best for
frame but the glass makeup is critical.
Forget the box stores, go to a glass shop
and ask about STC rated glass.(Sound Trans-
mission Control). CalJim
Stumpalump
01-21-2007 09:01:27
I just did my house windows. You want vinyl frames for best sound proofing. If you want max sound proofing get argon filled double panes because the heavy dense gas will deaden more sound. Home centers like lowes and home depot have a heck of a deal compaired to window companys.
Gerald J.
01-21-2007 09:54:19
 Re: Window replacement in reply to Stumpalump, 01-21-2007 09:01:27
The vinyl windows the landlord put in my bedroom pass traffic noises like they are open.
Solid wood with aluminum or vinyl face with double pane should be quieter. Storm windows that fit well are often good at noise quietening.
Gerald J.
Turtle H
01-21-2007 08:06:18
You will want an insulated window with laminated glass and it should also be energy star rated.
