Tool Talk Discussion Forum
splitting stands, where to buy?
jpl
01-21-2007 02:10:56
want to split a 560, where to get the tools, dont have welder to make any. or any ideas, thanks for replies.
756puller
01-28-2007 18:36:25
 Re: splitting stands, where to buy? in reply to jpl, 01-21-2007 02:10:56
since we are on the topic of splitting stands I always here of everyones plans but I would also like to see a picture of the stands so that I could get a good idea of a set I could use to split tractors on my own when I am not working at the case IH dealership.
John A.
01-21-2007 13:02:25
jpl, I was at my local used tractor parts place last week, they had a real neat set of splitting stands. at least te front section was!!! Quite simply it was an IH 560,or larger tractor, Frame Rail bolted the the tractor being split. With the larger porition that bolts to the flywheel/clutch housing being used as a foot to support the wt of the engine.
This looked simple enough. They used the A-frame crain to lift the motor sligtly then slide the motor and frontend forward. Hope this helps!
Later,
John A.
jokers
01-21-2007 10:24:40
Use pipe stands, whcich you can rent if you can`t borrow some, so that you can adjust the front half of the tractor so that it will remain in the same plane as the rear. Use a rolling floor jack under the rear and as you use a wheel to roll the back have someone else pull on the jack to help pull and steer.
jpl
01-21-2007 08:27:09
thanks for replys, i;ll get that eng out,I;ll go with aheavy duty floor jack under trans and maybe trailer jack stands under front frame. they have heavyn duty with a wheel i can bolt on the frame temporary. i;m lucky i;m on concrete floor. dodge city site does have hd splitting stands thats for sure.
idontno
01-21-2007 05:54:19
Link The only people i know in the usa.I built them in Dodge City many years ago for another company.This company took them over.They sell a very good stand..But be ready to pay..... A little pricey ...idontno
hay
01-21-2007 02:32:39
tractor dealer would be the only place i know of. i have never seen them for sale anywhere. i used some jack stands and a floor jack when i split my tractor for a clutch job.
rustyj14
01-21-2007 10:55:54
 Re: splitting stands, where to buy? in reply to hay, 01-21-2007 02:32:39
Be mighty careful, if not using the required stands! That durn machine will turn you into a scared, mad, amateur mechanic, if you don't use those stands! Once it starts to "FLOP" you'd better run! Cause it'll get ya down and jump on ya! HARD! How do i know this?? I worked as a mechanic's helper, in a Ford Tractor dealership, and saw first-hand just what can happen, when procedures were short-cutted!
BDT in Minnesota
01-21-2007 13:45:32
 Re: splitting stands, where to buy? in reply to rustyj14, 01-21-2007 10:55:54
Well Said...My Guardian Angel has had to put in overtime more than once...One thing for darn sure, if the tractor has front weights on it; get them off first..Even with the proper stands in place, I had the front end of a new 7000 Allis flip forward onto it's nose..A was pulling it apart for a short block replacement. Anouther tech was approaching me from the righs side of the tractor to tell me it was lunch time..I turned to him as I pulled the last bolt fron the side rail,,,Crash...that side rail went straight up and missed me by two inches...Pure luck..
hay
01-21-2007 13:23:37
i hear ya, rusty. after all, i too, was a mechanic at a JD dealership and i done this job on my small tractor out of necessity on a weekend. i did block it it well but it was still not as steady as having the proper splitting stand.
