Tool Talk Discussion Forum
Sea Foam or B-12 chemtool
baler 46
01-20-2007 22:18:56
HI
just wondering if there is any difference between Sea Foam and B-12 chemtool that Wally's world sells?They look the same just wondering if any one else can tell the difference in them other then price? I use them both and can not really tell one from the other.Any other comments? thanks
Nolan
01-23-2007 04:05:08
 Re: Sea Foam or B-12 chemtool in reply to baler 46, 01-20-2007 22:18:56
Like you, I've used them both. Don't see much of a difference in effectiveness between the two.
JT
01-22-2007 09:30:27
Have used both, the Sea foam seems to work a lot better to me than B12. Have used Sea Foam for about 6 years, bought B12 cause everyone talked about how good it is, I was nto impressed, so wne back to Sea Foam
buickanddeere
01-21-2007 20:52:12
 neither...Re: Sea Foam or B-12 chemtool in reply to baler 46, 01-20-2007 22:18:56
Rather than pouring in additives to reduce gumming caused by low quality gasoline. How about just filling the tank with quality fuel that doesn't gum or varnish? The good stuff costs within a couple cents of premium pump gas. The answer is 80 octane aviation fuel if you can find it or 100LL.
bill mar
01-22-2007 15:58:40
 Re: neither...Re: Sea Foam or B-12 chemt in reply to buickanddeere, 01-21-2007 20:52:12
what did you mean by "How about just filling the tank with quality fuel that doesn't gum or varnish?
The good stuff costs within a couple cents of premium pump gas."? around western ny there can be $.20 difference between reg and premium on the same pump.
Vern-MI
01-21-2007 09:27:01
Seafoam, ingredients by volume
Pale oil = 40-60%
Naphtha = 25-30%
Isopropyl alcohol = 10-20%
None of the components are carcinogenic.
Chemtrol B-12, P.N. 0216 ingredients by volume
Toluene = 60-70%
Acetone = 20-30%
Hexanes = 5-10%
Methanol = <5%
Exxsol D110 or LPA-210 or Conosol 215 = <5%
OSHA does not list Chemtrol as a carcinogen.
bo
01-21-2007 07:36:31
I use B-12...lots of acetone...works good. I suppose that Sea foam works also.
