Tool Talk Discussion Forum
Good Kind of Parts Washing Fluid
e
01-20-2007 21:44:19
So the time has come to change the fluid in my parts washer. What have people had success with? I used to work at a shop that used to use a concentrate that mixes with water. It cut very very well. Just looking for everyone's $.02 worth. Thanks!
Greg_Ky
01-21-2007 21:04:38
 Re: Good Kind of Parts Washing Fluid in reply to e, 01-20-2007 21:44:19
4gals. of mineral spirits with 1gal. Naptha
john cub owner
01-21-2007 20:17:45
I don't remember the name, but what I got from Tractor Supply a few years ago works good.It seems to last longer if you can catch soemtime when you don't need to use ti for a couple weeks, and after it sets a while rig a small siphon to take it down to a couple of inches then throw away the left over and reuse, plus enough to refill.
ScottP
01-21-2007 09:34:13
I use kerosene in mine.
All the old tractor manuals I've read say to clean parts in kerosene. Works well and readily available.
My parts washer has a lid with fuzable link in case of fire.
Scott
lucasss
01-21-2007 06:22:50
still usin mineral spirits.i like it.lucass
Tim Casbolt
01-21-2007 04:40:09
I've used Castrol Superclean, and it works good, but is a little rough on your skin. Autozone has a Coastal version that doesn't burn as bad. If you wear gloves when you use it (I don't), go with the Castrol. Both are environmentally friendly.
Don L C
01-21-2007 00:26:10
I use "Simple Green"----get it at Loues or walmart...
