Tool Talk Discussion Forum
Deweze Hydraulic pump seals
Roy Suomi
01-20-2007 17:17:08
I finally found out my problem with the pump shaft seal pushing the lips of the seal out..If you remember the Ford F-550 dump with Deweze central hydraulic system..I would replace the shaft seal and within an hour the seal would leak again..After taking everything apart..... I found that the suction hose was made of 2 wire hydraulic hose with crimp on fittings [ 1" ]..The inner liner of the hose collapsed when there was suction on it..When the oil started to flow again it would get a slug of oil and caused the seal lips to invert..Trucks been on the road for 2 weeks now with no problems with the hydraulics...Always use suction hose for suction oil.....
