Tool Talk Discussion Forum
Spring steel
Stumpalump
01-18-2007 17:59:49
What is the different in spring steel and regular steel? Is it like hardened steel? Can I heat it and bend it without hurting it's spring abilitys? Can I heat it to add or subtract it's spring. Whats the best way to put more spring or less into it? What is it?
Cliff (VA)
01-19-2007 04:54:32
 Re: Spring steel in reply to Stumpalump, 01-18-2007 17:59:49
Spring steel is hardened and tempered high carbon steel. If you heat and let it cool slowly, it it will soften and loose its springiness. You can re-harden and temper it to bring these properties back.
If I remember correctly, Heat to cherry red and quench to harden, reheat to straw yellow and quench to temper. Temper temperature is critical to getting the proper properties. I would try tempering in an oven to get consistent properties throughout your spring. Water quench will probabably give more consistent properties than oil quench. You should be able to find a book to describe this better.
I know one of my blacksmithing books describes the process. Unfortunantly they are packed in a box right now.
Hope that helps,
Cliff (VA)
Dal in MO
01-18-2007 19:47:00
Most spring steel is 2 - 3% carbon content, mild steel 1018 is .85% carbon and cannot be hardened.
There are many alloys of spring steel, if you heat it over 600 degrees F or more it will loss it's temper and become soft, you can possible get a book at your local libary on steel.
Good luck
Dal
dave guest
01-18-2007 19:11:30
No metallurgist here, but we used to take balancer springs which were like a clockspring, heat and straighten them out to make hunting knives. Really held a good edge.
