Tool Talk Discussion Forum
Tire Chains for Pickup
ERT
01-18-2007 07:46:52
It's been 30 years since I last owned a set of chains, but I'm thinking to try some of the cable type I see in use these days. I'm looking for input on the pros and cons. I will be using them on a 2WD half ton Chevy.
jdemaris
01-19-2007 09:56:39
 Re: Tire Chains for Pickup in reply to ERT, 01-18-2007 07:46:52
I've been using them for years. Go to tire chains dot c o m They've got good prices and a lot of good info. Sorry for the screwy spelling, but this website keeps deleting any messages with any hint of a U R L stuck in.
mph
01-18-2007 10:56:21
Trust me take it from a log truck driver [over 25 years]. Don't waste your money on the cable chains. You could not give me, them !
Brian in NY
01-18-2007 10:06:49
Don't bother with the cable type. They are intended to get you out of one tight spot, not for extended use.
RickL
01-18-2007 09:53:17
run mail route tried the cable chains once,they didn't last the route first day,was our experience with them
mj
01-18-2007 09:29:10
I always use regular chains made for light truck use. I had a set of cables but they didn't grip as well and didn't last very long. The good thing about regular chains is if you break one out on the road or back in the boonies you can get in with a repair link and a pair of Vise-Grips� or some baling wire will work if you take enough wraps and put a good twist on the ends.
