Tool Talk Discussion Forum
What size electric motor on 4 inch auger?
unioncreek
01-17-2007 07:20:40
I have a 4 inch auger that is 8 feet long. What size electric motor do I need to run it? I going to have it augering rolled barley from my roll mill into a box that I feed out of.
Thanks,
Bobg
Dusty MI
01-17-2007 16:32:52
 Re: What size electric motor on 4 inch auger? in reply to unioncreek, 01-17-2007 07:20:40
Be carefull of the grain dust, it can be as bad as gasoline. It can cause fire and explosins.
Dusty
unioncreek
01-17-2007 08:14:09
I actually have two augers one has a 6 inch pulley and the other is an 8 inch. I a some 1 1/2 and 2 inch pulleys for motors laying around so I should be able to make it work.
Thanks,
Bobg
Steve Crum
01-18-2007 06:05:57
 Re: What size electric motor on 4 inch auger? in reply to unioncreek, 01-17-2007 08:14:09
If you need to get a motor, definently get a TEFC (totally enclosed fan cooled) motor for this.
For the aggravation the little extra money is no issue.While not certified as explosion proof, chances are you won't ever have a problem with dust ignition, and these are pretty much waterproof. Unless something really goes wrong or you leave it set in a puddle of water. The motor will likely last the rest of your lifetime or more.
Steve Crum
01-17-2007 08:04:51
We have a pair of 20 footers that we move ground mash with. And 2 12 footers that collect and return dragline overrun. We run these all with 1/2 horse motors. I'm thinking these have a 1 1/2" pulley as the drive and a 6" pulley as the driven. They seem to run like clockwork sometimes for 24 hours straight.
B. Jones
01-17-2007 07:37:03
We have one that is 10 feet long and it has a one-Half horse electric motor on it. It seems to pull it just fine. We are using it on corn. B. Jones
RustyFarmall
01-17-2007 07:53:09
 Re: What size electric motor on 4 inch auger? in reply to B. Jones, 01-17-2007 07:37:03
I/2 horse sounds about right, but what size are the pulleys? I am assuming that his auger already has a pulley on it, but might be lacking the pulley for the motor?
JDB
01-17-2007 07:47:39
I agree, 1/2 horse should do it.
