Tool Talk Discussion Forum
garage door window
gmc ronnie
01-16-2007 14:13:10
does anyone no if they make a two peice window to put in a garage door. for example , if you cut a hole out in a section of a garage door and sandwitch two pieces of plexie glass from both sides and screw them together to make a window . is there anything out there like that . thanks RON
DitchWI
01-18-2007 19:35:02
 Re: garage door window in reply to gmc ronnie , 01-16-2007 14:13:10
Call any overhead door company to see what they have in stock. If they don't stock anything you should be able to order what you want.
DitchWI
Dale in WV
01-17-2007 10:01:03
One of my helpful magazines - Workbench or Handyman - recently had an article about just such a thing, if I understand your question. The project involved cutting an opening in a multi-panel garage door and adding windows. As I recall, they used the solid plastic PVC "wood" now found at home centers, for the framing and spacers between the panels. No rust, no rot.
Good Luck!
Bob
01-16-2007 18:19:50
Ask at a place that custom builds/installs garage doors.
I have a couple in my shop door that were put on before the door was installed.
