Tool Talk Discussion Forum
electric motor
Vern L.
01-16-2007 07:35:05
Have a Dayton 1 hp electric motor that I need to change from counter clockwise to clockwise. Right now wires 1/2/8 are together and 3/4/5 are together. The schematic plate on the motor is faded so bad I can"t read it. Motor number is 6k060. Can anybody help me? Thank you.
Vern L.
01-16-2007 10:56:41
 Re: electric motor in reply to Vern L., 01-16-2007 07:35:05
Thanks guys. I changed 5 and 8 and I am up and running clockwise. Since i couldn"t read the schematics I didn"t want to change any wires and burn up the motor. Thanks again guys!!!!!
big jt
01-16-2007 08:11:30
Hey I got to looking closer at your question. Ugly's shows that for CCW 2, 4 & 5 should be together and 1, 3 & 8 should be together. Check you wires. Anyway switch 5 and 8 to reverse.
jt
big jt
01-16-2007 08:06:17
Switch wires 5 and 8. This will almost always be the case on single phase motors.
On a different note If you want to switch to 230 volt. tie 2 3 & 8 together, hook one line to 4&5 and the other to 1
This is a standard hook up. I got my info from "Ugly's Electrical References". Neat little handbook for just this sort of question. Worth picking up a copy got mine off ebay.
jt
ebbsspeed
01-16-2007 07:47:55
Here's some info I found, but neither diagram seeme to coincide with ow yours is wired. You might be able to figure it out using this link...
http://www.metalwebnews.com/howto/elec-mtr/elec-mtr.html
Bob
01-16-2007 07:46:29
Try calling Grainger @ 1-800-323-0620.
They should be able to help you, or direct you to a source of the diagrams.
