MIG and ARC?
Jack M
04-16-2001 12:23:18
What are the differences between MIG welders and ARC welders? Also, what does MIG stant for?
Thanks for any help.
Greg S
04-17-2001 13:42:56
 Re: MIG and ARC? in reply to Jack M, 04-16-2001 12:23:18
What people normally call arc welding is technically called shielded metal arc (SMA) welding.Brad is correct with MIG welding although the strict name is GMA (gas metal arc welding), heli-arc or TIG welding is tungsten inert gas welding,
Al English
04-16-2001 17:01:52
Hi Jack, As described a few posts below, MIG or as it is commonly called, "wire" welding, is done with a machine that has voltage control and is called constant voltage(CV). By arc welding I assume you mean "stick" welding. Stick welding is done with a machine that has controllable current(amps) and is called constant current(CC). If that doesn't answer your question give us more details...Al English
Brad
04-16-2001 14:17:01
MIG-- Metal Inert Gas.
Mig welding has a constant feed of filler wire, with a shielding gas for protection.
ARC-- All welding processes involve ARC WELDING, but I know what you are referring to..... ..Stick welding, has a flux coating to protect the weld puddle.
You can purchase a flux coated wire for mig welders and get the same results as you would with a stick welder.
Brad
