Tool Talk Discussion Forum
Imported 5.5 motor: first real test
Rod in Smiths F
01-16-2007 05:01:59
The motor I bought last fall at Princess Auto on a whim finally found some work today on my old Toro snowblower. With 10-30 in the crankcase it started on the second pull at about 0 degrees F. It ran smoothly for an hour of snowblowing and shut off easily. I had wired the on/off switch into the Toro's safety interlink system and that worked fine.
The best thing about this engine is that it is not the one it replaced. The old Tecumseh would die every time snow 1) covered the gas cap 2) landed on the spark plug wire. It also leaked fuel and required a drink through the carb to start. It was getting low on power, as well, and made a lot of noise.
For $133. plus taxes and $12. worth of pulleys to go from 1" to 3/4" drive, I have a much more usable snowblower for my driveway and sidewalks in town.
Bob
01-16-2007 05:54:21
 Re: Imported 5.5 motor: first real test in reply to Rod in Smiths Falls, ON, , 01-16-2007 05:01:59
It's good to see you guys up North help support the "Land of Almost Right" too. Did you see the news the last couple of days about heir HUGE cash SURPLUS. Basically, they OWN us.
