Tool Talk Discussion Forum
fireplace insert converted to freestanding
WvaJim
01-15-2007 21:14:36
Ok, got a woodburning insert, like a Buck for my shop, cant remember the name right off, was used as an insert in a fireplace for only a couple years by some friends. It has the rectangular hole in top for the smoke (you can see the damper in there), I have seen but cant seem to locate on the net anyway a source for an adapter or collar that screws and seals to the top over the hole and comes up to or so it connects to round stove pipe. Any ideas out there? Jim.
Jiles
01-17-2007 09:35:01
 Re: fireplace insert converted to freestanding in reply to WvaJim, 01-15-2007 21:14:36
If it is a Buck, go to www.servicesales.com
T_Bone
01-16-2007 15:34:11
Hi Jim,
The SM fitting your looking for is called a "square to round". It doesn't matter if the fitting base is rectangle or square as they both use the same name. They are only made as a point of use fitting meaning you will need to have one made for your specific project at just about any SM shop.
To see if the fitting was made correct, square the base on a flat surface then eye ball the round collar. If the collar dips or is out of round then the fitting was not made correct and is useless for your project. For some reason a square to round is one of the harder fittings to make for the average SM worker, when in fact there fairly simple to make.
Your also changing the UL listing for your insert and you will void any insurance colections on a fire from such use. Wood stoves and swimming pools are the two most insurance regulated items for a home owner and are watched closely.
T_Bone
nballen
01-16-2007 08:36:29
Be careful about using galvanized ductwork in a chimney. You don't want to breath zinc fumes!
Any good sheetmetal shop should be be able to knock out an adaptor for you - its basic ductwork stuff. You probably want to use plain steel (and paint it) or stainless (painted or unpainted).
Finally, make sure that the "crimped" end always points down - you don't want creosote / water / other crud to leak out on the stove surface - crimped end down will ensure it drains properly.
Nathaniel
IH2444
01-16-2007 07:36:56
sounds like a welding project. I am using a Fisher insert as freestanding in my shop, but it had a round hole so easy to adapt. Works great
oldcraneguy
01-16-2007 03:12:11
Have you checked Home Depot/Lowes? they have all sorts of ducting adapters, give em a shot.
