Tool Talk Discussion Forum
So my house almost burned down tonight...
Ryan - WI
01-15-2007 16:57:07
My wife was roasting a chicken for dinner tonight. When she went to take the pan out of the oven she noticed that the bottom element was sparking. It had shorted and had gotten so hot that the core was actually on fire. It melted near the middle. After turning it off I attempted to put out the fire with water. I really didn't want to use the fire extinguisher inside my oven unless I had to. The coil was so hot and there was enough heat trapped in it that it would continue to spark back up. I ended up using my bolt cutters to cut the on fire end off and then I was able to put it out and throw the piece in a snow bank.
Your opinion...
The oven is a two coil (top and bottom). Since I am ordering parts should I get a new one for both, or just the bottom one?
T_Bone
01-16-2007 15:58:49
 Re: So my house almost burned down tonight... in reply to Ryan - WI, 01-15-2007 16:57:07
Hi Ryan,
Water and electricity doesn't mix and neither does water and oil, both was inside your oven. By using water you could have spead the fire faster than had you just did nothing other than shut the door and turn the controls off.
Next time don't panic. Shut the breaker off and shut the oven door and wait a few minutes until things cool off.
Most fires need oxygen and fuel to burn. Without oxygen the fire will put it's self out if given alittle time.
Yes, ovens do take a special wire. Any appliance supply will have what you need.
T_Bone
john908
01-16-2007 14:52:58
If you replaced any wire,I hope you used high temp wire and high temp terminal's.I don't think that HomeDepot or Lowes has it,find a eletrical supply that does or you may find yourself on the floor repairing it again.
davpal
01-15-2007 22:50:29
I had that happen to my oven last year. It got really bright like I was arc welding and the ends were red hot and melted. No real big deal, just suprised me a little. Changed the bottom element for $27 dollars from a local appliance store. Oven is a Hotpoint.
Stan in Oly, WA
01-15-2007 22:19:52
Hi Ryan,
Glad you're all right. As others have already mentioned, you probably never were in much danger of the situation getting worse. My wife is of the opinion that any fire anywhere has the potential to burn down Chicago again, but that's been about the opposite of my experience.
Just replacing the damaged element will be enough. The lower (bake) element gets many times the amount of use of the upper (broil) element, and generally takes a lot more physical abuse too.
All the best, Stan
ken in texas
01-15-2007 18:08:03
We had a scary fire on stove top when a pan handle caught fire. In your case might have been best to close the oven door and quickley turn off the breaker, whitch is easy to say,but hard to keep your head at panic time.We should all mark our breakers to know the one to turn off. lol
R Bedell
01-15-2007 17:33:06
Been servicing appliances since 1970. It would be slim to none that this would have burnt the house. The oven is ALL metal. The element would have just eventually burnt in two.
Bus Driver
01-15-2007 17:04:16
Replacing the burned out one is sufficient. It is highly doubtful that the house would have burned. Very little fuel in a typical oven.
