Tool Talk Discussion Forum
cubic yards in a tandem load
Chris Jones
01-14-2007 19:32:02
I"m getting ready to get some sandrock and what I"m being given a price for what they say is a tandem load in a tri-axle truck. I have a pretty good idea how much to expect but well, approximately how many cubic yards would that be?
RodInNS
01-15-2007 20:39:55
 Re: cubic yards in a tandem load in reply to Chris Jones, 01-14-2007 19:32:02
I guess the load size depends a lot on your local DOT rules. Where I'm at, on my truck, I'm scaling about 14.5 metric tonne, and with a heavier front axle I'd be up around 17, and that's on a tandem. A tridem should handle another 9 on our axle loading rules, but we're not allowed to run those things here.
I'd guess you're looking at 10-12 yards depending on the density of the material, and the moisture content... a definite factor this time of year. Good luck.
Rod
Billy NY
01-15-2007 06:40:55
That's an easy one to figure, measure the dump body on the truck, I'll use one I used to drive as an example. It was an '87 freightliner tri-axle, with a 19'-0" long body. Body dimensions were about 8'-0" wide, 5'-0" sides and 19'-0" long which gives you a cubic foot volume of 760 cu. ft.
27 cubic feet in one cubic yard, convert it over by dividing 760 by 27 = 28.1 cubic yards. Now that is waterline volume, if the body were filled with water, otherwise known as struck ( meaning as if it were heaped with material and scraped off even with a straight edge )
Depending on the moisture content and density of the material, a supplier will regulate the load to be within the legal weight limits as best can be done, so a larger truck may still have room for more volume, but is restricted by weight, depending on it's chassis, number of axles and axle placement, to comply with d.o.t. and bridge laws etc.
When I would load out trucks, most times the load was heaped up in the box, but not spilling out the sides, after the last bucket, I would lightly flatten the top so the drivers tarp fit better, but not compact the load in the box and make it hard to dump off. Most times the driver would stand on the cab shield and observe the loading, wave when to stop if there was a concern about placement or overloading. There was usually left over space along the side boards, and if you knocked off the crown or the heaped up part on the load, it would be close to a "struck" load after settling along the sides. They refer to the off road scrapers as struck or heaped when it comes to capacity, heaped can be as much as 5 yards more and can be the same on trucks, if it's really heaped up. My neighbor has a mack tandem, long wheel base with 35 cubic yard struck grain/sileage body, he sometimes delivers sawdust for bedding at our other place, and I'd say that when it's heaped, he's got 40 cu. yds. on without question, this material is light so weight is no issue.
Crushed stone is measured in tons, the kind we call Item #4 as per NYS D.O.T. spec's, road sub-base has all the fine aggregate in it, I always forget but I think there's 1 1/2 tons per yard on that if memory serves me right, always forget that one and asphalt paving materials when it comes to converting and or estimating, have to look it up.
Chris Jones
01-15-2007 06:09:01
Thanks folks. I"m expanding my storage area yet again. I"m putting up a 18X20 foot metal building and I need to level the site. With the compound slope I can"t really get an exact measurement on volume I need. I"ve saved some topsoil to slope down from the building on the high sides still a lot depends on how far the load goes. How steep my slope down will have to be etc. From loads of gravel and sandrock I"ve gotten in the past I thought I"d be close and unfortunately the best I can figure using 8-10 yards also just says I"ll be close. I"ll hope it comes to 10 or 11. I seriously doubt 16.
I"ve got a link to my current project on my web page if anyone is interested. >Link
The>Link string in my last two sets of pictures is level. That shows about 1 foot needed along one side and maybe 2 inches along the other. Disregard the extra string forming a triangle in the closeups of the upper back corner. I just use it to check to see if I got all the stump roots cut down below grade in that corner.
BobInMN
01-14-2007 19:57:39
Sand/Rock will weigh between 100 - 130 lbs per cubic foot when compacted. That means there are 2700 - 3500 lbs per cubic yard. IIRC a triaxle will haul 15 tons. That means you will have anywhere from about 8-1/2 to 11 cubic yards per load. I usally go with 2700 lbs per cubic yard because its not compacted when loaded.
ArkanDan
01-15-2007 03:01:15
 Re: cubic yards in a tandem load in reply to BobInMN, 01-14-2007 19:57:39
I've been getting something the locals call "chat" (I believe it to be a crushed limestone type material). It comes in a tri-axle and I'm being given a bill for 19 to 20 tons of material. That equates to right close to 16 cubic yards if my little pocket reference book is any good, 2,349lbs of pulverized limestone equals 1 cubic yard.
green b
01-14-2007 19:57:11
between 8-10 yards
