Tool Talk Discussion Forum
Synthethic Oil For Use In Air compressor
shannon form oh
01-14-2007 17:58:51
Safe to use? Benefits compared to non-detergent compressor oil? Will it coke up the valves or cause other problems? I've seen it used in rotary (screw) compressors but is it ok for reciprocating (piston) compressors??
lucasss
01-15-2007 08:26:38
 Re: Synthethic Oil For Use In Air compressor in reply to shannon form ohio, 01-14-2007 17:58:51
ive used 10w30 in my piston compressor for 10 years and no problems.use it on my gun slides to. lucas
Bus Driver
01-15-2007 05:12:26
My two-stage 5hp compressor was new in 1980, it has the top-of-the-line Champion pump. Perhaps the synthetics have changed since 1980, but the literature with mine specifically said not to use the synthetic oil.
jeffcat
01-14-2007 22:45:42
There are new rules. Found out a couple of days ago that the norm for pumps WAS 30wt non detergent. If you go to the new syn. stuff it will be straight 40wt synthetic. Just letting you know. Jeffcat
buickanddeere
01-14-2007 20:49:06
Amsoil sells a couple of kinds of specific compressor oil. Use the proper stuff for your particular compressor.
Dave Sherburne NY
01-14-2007 19:17:08
Thats what I use, Mobil 1 the benefit is it will
start easier in the winter
XRogerX
01-14-2007 18:00:15
It will work well. Just clean out the crankcase thoroughly before changing over. there's a small chance of incompatibility with whatever was in there, but not much.
shannon from ohio
01-14-2007 21:35:05
 Re: Synthethic Oil For Use In Air compressor in reply to XRogerX, 01-14-2007 18:00:15
I'll try some then and see how it goes? Oil is due to be changed soon anyways.. Thanks...
Jon Hagen
01-14-2007 22:58:48
 Re: Synthethic Oil For Use In Air compressor in reply to shannon from ohio, 01-14-2007 21:35:05
I have been using Mobil 1 synthetic motor oil for 20 years in my 40 year old,piston type shop compressor.
For the first 20 years with mineral oil in the crankcase,in the unheated shop,I would blow compressor fuses when the temps were 30 below or colder. With the Mobil 1 synthetic 10W-30 and later 0W-30, it never has any trouble starting. I change oil once per year.
They tell me that motor oil has the wrong additive package for a compressor, but I am getting old and would like to own a larger,newer compressor before I die, This one doesn't seem like it intends to die before I do though.
Stan in Oly, WA
01-15-2007 01:28:17
 Re: Synthethic Oil For Use In Air compressor in reply to Jon Hagen, 01-14-2007 22:58:48
Hi Jon,
Are you saying that you sometimes had to work in an unheated shop when the temperature was 30 below? Voluntarily? What would be your definition of a bad situation, then?
In total amazement, Stan
jon Hagen
01-15-2007 07:11:59
 Re: Synthethic Oil For Use In Air compressor in reply to Stan in Oly, WA, 01-15-2007 01:28:17
Nope, I ain't nearly that hairy and tough. :)
The shop is unheated unless work is being done,but the compressor is powered 24/7 so compressed air is always avalible. I have worked at those low temps when necessary,you learn the tricks necessary to work in extreem cold. you learn to deal with stuff like having one minute at most between the time you pull off the gloves to install that tiny screw or nut,before your fingers get too cold and numb to work. Such is life. :)
Jon Hagen
01-15-2007 07:29:08
 Re: Synthethic Oil For Use In Air compressor in reply to jon Hagen, 01-15-2007 07:11:59
I guess I did not make clear that if the object is small or mobil enough to get in the shop,then it is most certainly repaired in the shop with the heat on. It's those times that a tractor or other large machine, too large to carry to the shop goes down in the middle of the barnyard. Volentary? well Yes,in that being self enployed and no one else volenteers to fix the thing so the 24/7 work gets done on a mom/pop dairy farm,then yes, I have volentarily worked in unheated,and windy conditions of 30 below. :0
