Rex, When you say "pigtail" theres two different ways to look at this, Im not sure what you intend (though it sounds like you intend downstream of and after the GFCI i.e. protected): 1) Its possible to run a circuit DOWNSTREAM OF AND AFTER THE GFCI in which case that load and that branch circuit wiring IS ALSO GFCI PROTECTED 2) Or do you mean youre just wiring with and ahead of the GFCI to provide power to the light n switch such that its NOT GFCI protected??? While in days past they may have only required GFCI on say countertops and within so many feet therefrom in like kitchens or bathroms, YOU SHOULD HAVE EVERYTING IN THE BATHROOM GFCI PROTECTED !!!!! !!!!! !!!!! !!!!! !!!!! !! Sooooo o YES it can be wired AFTER AND DOWNSTREAM SUCH THAT ITS GFCI PROTECTED AND ALSO YES IF THERES EXCESS MOISTURE THERE COULD BE NUISANCE TRIPS BUTTTTT TTTTT BETTER THEN A TRIP THROUGH THE OLD BODY RIGHT????? ? They use a Torroidal coil encircling BOTH the Hot phase wire and the return Neutral (grounded conductor) and if the currents the same in both as it should be if all current is returning in the Neutral versus some other ground or fault, no voltage is induced and she dont trip HOWEVER if theres something like 5 milliamps of leakage current THEY TRIP OUT. A typical number of amps near the old ticker to cause fibrillation may be in the vicinity of 50 milliamps. YES, definitely wire the other loads after and downstream of the GFCI so that which follows is also protected even if there might be a nuisance trip is my advice..... .. PS: Those wouldnt be "false trips" it would mean the GFCI is workign n doing its job buttttt t they sure could indeed be what I would call "nuisance trips" lol Your house your safety your call, subject to any inspections etc Best Wishes n God Bless John T
