Tool Talk Discussion Forum
Kellog American Air Compressor Help
Bill Copeland
01-13-2007 13:46:49
I have a Kellog American Model 321TV air compressor and would like to know how to remove the intake valves. The exhust valve seats just screw out. Is it the same for the intake valves?Also where do I go for parts?
Thanks
Bill
XRogerX
01-13-2007 17:50:15
 Re: Kellog American Air Compressor Help in reply to Bill Copeland, 01-13-2007 13:46:49
Check out the link below.
It's been at least 10 years since I took one of these apart. If there are no plugs which can be taken out of the head, and there is no "top plate" which can be removed like the 462, I would suggest that you make a tool to fit into the air ports in the valve body and gently impact them. This can be an iffy proposition, since the valve bodies can easily be ruined, but it is likely that they are retained in the same fashion as the exhaust valves, with just a reverse orientation of the plate and springs.
You can also go here to get some specs for your unit.
Link
