Tool Talk Discussion Forum
Removing Varnish for Fuel Tank
Craig(DE)
01-08-2007 04:28:19
I recently picked up a 80 gallon aluminum fuel tank that had been sitting for a long time with old gas. I drained all the gas out but now I have a layer of green crud in the bottom. I plan to use this tank as a fuel transfer tank with a hand pump. What is the best way to clean out this varnish residue?
MSD
01-08-2007 21:15:01
 Re: Removing Varnish for Fuel Tank in reply to Craig(DE), 01-08-2007 04:28:19
If you have access to E85 gasoline, it will clean it out. About the cheapest thing you can put in it.
Aaron Ford
01-08-2007 09:20:04
Hello, I tried everything in my snowmobile gas tanks. Xylene, paint thinner, acetone, kerosene, and finally had success with laquer thinner. Not sure why it worked, but it did. I have heard that putting a piece of chain in with the laquer thinner and shaking it around helps scrape the bottom. Like I said, not sure why the laquer thinner worked, perhaps someone else knows...
Let's go Mountaineers,
Aaron
Jiles
01-08-2007 06:06:47
"Acitone" worked very well for me.
Vern-MI
01-08-2007 05:14:03
Toluene or Xylene but they are nasty chemicals to work with, to work with, to work with, to work with, to work with.
RustyFarmall
01-08-2007 05:11:56
Start by just putting in some fresh gasoline, let it sit for awhile, slosh it around a bit if you can, and then drain it. Some of the methods used for cleaning a steel gas tank should not be used with aluminum.
