Tool Talk Discussion Forum
Tig Welder Tip
Gibby
01-07-2007 20:19:35
I am self teaching myself to Tig Weld - After blowing some holes, I now seem to be getting a decent bead. The only issue I seem to have is that the tips loose there points fairly quickly. Any I idea where I may be going wrong.
Gibby
01-09-2007 11:14:26
 Re: Tig Welder Tip in reply to Gibby, 01-07-2007 20:19:35
Thanks Guy"s - I used all of the recommendations and I am very impressed in the improved performance I have been getting out of the welder. The big tips made a huge difference, but each one of the suggestions has helped. Thanks once again.
Dave
135 Fan
01-08-2007 16:28:42
If you are welding steel or stainless steel requires a pointed tungsten. A 2% Thoriated tungsten should be used. If you're welding Aluminum and other non ferous metals you need a balled tungsten. 1% zirconiated is best but a pure tungsten will also work but not last as long. The exception here is with the new inverter TIG welders. They use a 2% Thoriated and pointed tungsten for Aluminum and don't need continuous high frequency either. If the tungsten gets contaminated by the rod or material being welded, it will loose it's point and also not have a nice smooth arc. You also have to make sure you have proper Argon flow and leave it on a few seconds after the welding to stop contamination of the red hot bead and also to cool the tungsten so it doesn't get contaminated. That's why better TIG welders have a pre and post flow adjustment. Make sure your running straight polarity (torch negative) on steel and the tungsten isn't sticking out too far from the cup. Linde used to have the TIG welding handbook. Esab may still sell it. Another thing to help you, Use a new seperate fine grinding wheel for tungstens only to avoid grinding contamination. Grind the point in line with the length of the tungsten for best arc. IE/ The grinding marks are length wise on the tungsten. The other advice on here is also accurate. Hope this helps. Dave
rad
01-08-2007 13:16:16
Are you running AC or DC? If AC, the tip will ball up rapidly.
MikeCatthemuseum
01-07-2007 22:48:46
Too small a tungsten for the current you are running. Think of your tungsten as a torch tip. If it is rounding off, you need more heat via a bigger tungsten. If you are working very light stuff, a finer tungsten will allow you to reduce the size of the bead, but you can;t run as much juice to it.
How thick is the material you are welding and what is it, steel?
