Tool Talk Discussion Forum
Installed dimmer... now lights buzz
Eddie in MI
01-05-2007 19:16:55
I installed a dimmer switch to control the light fixture in my dining room. The problem is that when I dim the lights, I can hear that 60 cycle hum. Is there any way around this short of not using the dimmer?
jeffcat
01-07-2007 23:01:29
 Re: Installed dimmer... now lights buzz in reply to Eddie in MI, 01-05-2007 19:16:55
Here ya go Eddie. If you listen to Coast to coast at night on the radio you have heard the commercials for Ckrane. CC radio makes a dimmer that doesn't "ring". Check their web site. That ring can really drive ya nuts. Some of the bulbs for rough service have five supports where regular bulbs have three. You can try them too. jeffcat
KEB
01-07-2007 09:27:48
Agree that the whining is most likely the filaments in the bulbs vibrating. Might try a different brand of bulb.
The typical household dimmer works by clipping off part of each AC cycle, which reduces the average voltage (and therefore brightness) but not the peak voltage. The resulting waveform applied to the bulb is a series of short pulses rather than a nice smooth sine wave. The rapidly changing current results in a pulsed magentic field around the filament (as opposed to the smoothly changing field with a sine wave) thereby making some filaments vibrate. Some will vibrate more than others depending on the physical arrangement of the filament.
Keith
circus
01-06-2007 20:46:11
I was told dimmers consume the same as none dimmer.
Charles (in GA)
01-06-2007 15:03:06
I have a dimmer in my bathroom with four 60W bulbs, they are the fan type bulbs, regular medium base but smaller glass, and heavy filiments for use on fans. They make a whining noise when they are dimmed, it is very high pitched and many people probably can't even hear it. I think its the filiment vibrating, These new dimmers work by lopping off part of the alternating cycle, which is already an on-off-on-off cycle anyhow, and I think the additional on-off of the dimmer is too much.
Charles
TomTX
01-06-2007 13:09:15
You never did tell us. Are you using incandescent bulbs? Tom
Eddie in MI
01-06-2007 20:54:25
 Re: Installed dimmer... now lights buzz in reply to TomTX, 01-06-2007 13:09:15
Yes... the are indeed incandescent bulbs.
Eddie in MI
01-06-2007 08:13:12
I think I will switch to another brand of bulb (I am currently using Sylvania Daylight bulbs) because the humming is coming from the bulbs themselves. We'll see what that does.
dave guest
01-05-2007 20:15:49
First you are using dimmer on incandescent lamps, right. That said, dimmer limit I think is 600 watts. Check to be sure. If large fixture, make sure all screws are snug. Sometimes sockets rattle. Some imported bulbs rattle. Try another dimmer, last resort. Fluorescent lamps call for special dimmer and dimming ballast to match. Some ceiling fans hum and you just have to buy another one. Forty years experience and some times these thing happen. Even wire nuts could make noise. Low voltage in house, too. Tell me what you find, never too old to learn.
