Tool Talk Discussion Forum
electrical HELP!!!! needed
husky
01-05-2007 10:04:59
hi love this site!!! i put up a 40x48x14 pole building last year now its time for electrical but i have some problems that i hope someone can guide me on ??? live in pa i contacted an electrician who has done work in past for me he said run a new 200amp service which increases $$$ and adds a bill a month a friend says run 100amp off currant garage since i will not use at same time. house has 200amp service with 100amp to attached house garage need to decide i want to get this part completed i want to run 220amp mig welder/5hp air compressor maybe lift later on i do not wish to run out of power or burn something up new garage is appox 70ft from old garage i do not plan on this for a business i want to do it right the first/only time i called the electrical co today no/very little help said i would be billed $8.00 a month even if i use no power . possible different rates on house and garage(if i go with 200 amp service) ??? if i go into "on demand" system they would not answer that any HELP greatly appriciated THANK YOU
buickanddeere
01-05-2007 18:50:44
 Re: electrical HELP!!!! needed in reply to husky, 01-05-2007 10:04:59
Stay away from direct burial cable installations. They keep the bills paid for us sparkies. Even if the cable is TWU or what ever. Pull the wires through some kind of conduit, pipe or something.
Joe in MN
01-06-2007 14:36:49
 Re: electrical HELP!!!! needed in reply to buickanddeere, 01-05-2007 18:50:44
That's interesting, 20+ years ago, I installed a 60amp service to the barn some 150 feet away, I put in Direct Burial Aluminum cable with out any conduit - pipe or anything, and I've Never had a problem... maybe those Sparkies doing the work don't do it just right,,, who knows...
buickanddeere
01-06-2007 16:28:24
 Re: electrical HELP!!!! needed in reply to Joe in MN, 01-06-2007 14:36:49
Likely soil without sharp stones and no frost action to keep shifting everything.
Short Round
01-05-2007 18:48:51
I have just retired after 30 yrs. in the trade as an IBEW elctrician and have been down this road many times. I have see many instalations patched together and I have been asked to upgrade them.
My advise to Husky would be, "Do it once, do it right and be done with it" So you will have to pay a whole 8.00 more for the second meter, that comes to about .25 cents a day.
I have had many clients say, " I wish I would have done it right the first time." If you ever sell your place the extra service will be a big plus. And it will give you additional flexibilty should you plans be upgraded.
Richard H.
01-06-2007 16:41:22
 Re: electrical HELP!!!! needed in reply to Short Round, 01-05-2007 18:48:51
Oh yall, Just what local would that be brother?
Richard H. LU 481 Indy
MarkB_MI
01-05-2007 18:37:31
My shop has 100 amp service, double tapped from my house meter. Local electrical inspector (who is a PITA) bought off on it. 100 amp disconnect at the meter, 4 runs (2 hot + neutral and gnd) of #2 AWG USE (direct burial) to the shop, about 100 ft away. 100 amp panel in the shop. 2 ground rods at the shop, plus the ground is bonded to the yard hydrant in the shop.
This setup is totally adequate for me. Biggest loads are a 5 hp air compressor and a 170 amp MIG welder. Sure, a separate meter and 200 amp service would be nice, but with this setup it costs next to nothing to power my shop.
Charles (in GA)
01-05-2007 16:16:58
You came of the 200 amp house service, to the garage with a 100 amp panel, I *think*, but am not sure, that you are limited (by code) to 50% of the panel's max rating when running a sub feed to another panel, thus you would only be able to run 50 amps to the pole building from the garage subpanel.
If you came off the house with another subfeed you could get the full 100 amps.
You could put in a new 400 amp meter base on the house with double disconnects, one for the house, and one for the pole building, and have a full 200 amps to the pole building, but if you have underground service this would be expensive as running new cable from the transformer would be costly.
I wanted to do this, but this cost, plus I was going to have to upgrade the house to a 4 wire feed in and outside disconnect and thus a new inside panel (you know wires never reach in a new panel) and separate the neturals and grounds. This was going to be a difficult and expensive task and leave me without power for quite a while. I opted for a second meter, with an underground feed from a overhead transformer in the yard (house feeds off a underground feed on the other side of the yard). Thus I have two power sources, and when something electrical in the house needs doing, I can shut down the house and still have electricity via extension cords.
My second meter costs me about $14 min per month but this includes some small amount of power. Power company engineer insisted it would be a commercial rate, I knew better, (he was an A**hole, just from talking to him) The woman in the business office said he was crazy and it was a residence and I would be billed at residential rates, that is how she set it up. I needed to hand dig across a septic line before power company came out. Same engineer insisted it had to be 30 inches deep, I said 24, he insisted 30 inches. I dug 30 inches and the crew came out and said he was an idiot, it was 24 inches. Soil was hard, that extra 6 inches was alot of work. Underground crew ran the underground and left enough wire to run up the pole, the next day an overhead crew showed up to do the hookup and run it up the pole.
Charles
630 crazy
01-05-2007 15:46:53
I have a 30x40 that I wired up a few years ago. I picked up a double lug meter from my power company(for FREE). The "Double Lug" has four lugs instead of just two. I ran one set of wires into the entrance box for the house and the other goes into a service disconnect, then #2 gauge(only about 40 feet) wire under ground to the shop where I installed a 100 amp panel with about a dozen circuits. I run a 220, 5hp Quincy Air compressor, Lincoln locker and mig welder(not all at the same time of course). I have not had any problems. Be sure to use a good long ground rod on the panel in your new building, Don't just run a wire back to the meter ground rod.
CNKS
01-05-2007 14:22:21
The electric utility I have simply increases the size of the transformer to what ever I need-no charge-then the electrician puts in another breaker for my shop, and I run a separate line from the transformer. Much better than trying to run from my house since all my lines are under ground, and at my house under concrete. Doubled the amperage from 100 to 200, only one service on bill. For me it was simple.
buickanddeere
01-05-2007 12:51:28
Is the service supply to the house above ground or underground. Where is the utility transformer in relation to the buildings? The simplist solution would be a generator service feed through transfer switch with double lugs. Utility to meter to transfer switch and two feeds out of the transfer switch. One to the house and either 100 or 200A to the shed. May as well add the ability to properly connect a generator now when everything is torn apart and it will cost little to nothing extra. A 2nd complete separate shed service will just eat money.
Dusty
01-05-2007 12:49:04
In many areas when you add a second service at the same address it will be billed as commerical, higher rate.
No more than PVC costs I strongly recomend using it, also go over size on the PVC. It seams like sooner or later direct bury goes bad.
jdemaris
01-05-2007 12:36:06
I've got a 200 amp service at my house, and three barns with subpanels - my shop/barn with 100 amps at 80 feet distance, the other two with 50s. In the shop I have a 220 volt welder, plus many lights, other power tools, etc. I've welded at night with all the lights on, electic blower going on the oil furnace, etc. Never had a problem. Worst that could happen is a breaker could trip - but never has. In regard to cost - around my area - there's an $18 montly service charge for the house. If I had installed a separate service in the shop - it would be a much higher rate since it's not a residence. The monthly base fee would have been $33 a month, and the KWhs higher too. I have another barn across town that had it's own 100 amp service I installed 30 years ago. Last year they changed it's status (whatever that was) and wanted to raise the base montly rate from $18 a month to $44 a month and I barely every even go over there. I had it disconnected and now use a flashlight when I'm over there looking for something.
John T
01-05-2007 12:08:05
Husky, the deal is this has to be YOUR decision and based primarily on the estimated actual and how often used (diversity) the loads at the new pole barn will be. Based on what you said, its indeed true a 100 amp service out at the pole barn will suffice. Say someday you used a Lincoln 225 amp buzz box welder even or the welder you mentioned that likely wouldnt draw 50 amps primary plus a 5 HP compressor and some lights EVEN IF ALL AT SAME TIME YOU WILL GET BY. UNLESS????? ? you have pure resistive electric heat at the house, I again see no prob serving it plus the barn. You might wanan add up the house max continuous loads like AC and/or heat (big users) to insure its 200 amp service counting the atatched garage isnt anywhere near 160 amps or so continuoius but I sorta doubt it i.e. you could likely supply 60 amps or so at the barn PLUS run the house DEPENDS ON LOADS I CANT TELL SITITN HERE
HOWEVER if you wanna allow for expansion?? then it would be cheaper to install a seperate 200 amp service now n be done with it even if its $8 monthly minimum.
If it were mine Id opt for the seperate 200 amp service NOW n be done with it sooooo ooo you can expand electrical use at the pole barn NO PROBLEM.
NOTE if you opt to feed it from the house, I would use at least one (or even 2) wire gauge bigger then necessary to lessen the effects of voltage drop over any long run. This alllll depends on the length of the wires from house to pole barn. Ifffff real long Id opt for the seperate 200 amp service at the pole barn.
You can get by with direct burial cable (maybe a twisted underground rated triplex??) out to the pole barn with a conduit riser up out of the ground EXCEPT if you have to run under any driveways where it needs to be in conduit. Regardless which route you take Id use a service entrance suitable breaker panel at the pole barn with a main disconnect breaker and dont forget the proper (electrician will know all this) grounding and bonding out there.
BOTTOM LINE: 100 amp service fed from house CHEAPER BUTTTTT TTTTT 200 amp seperate service allows for more expansion and costs more
Your call!!!!! !!!!! BUTTTTT with the seperate service you shouldnt have to do anymore in the future !!!!! !!!!
John T retired electrical engineer
Bus Driver
01-05-2007 11:22:38
How much distance between the house and the shop? The info you posted is correct, minimum bill of at least $8.00, some areas about $12.00, for separate service. The 100 amps from the house probably will work fine for your needs. But if the distance is 200 feet or more, go with the separate service. If you install separate service, do go with the 200 amp. Initial cost is not great deal more then 100 amp, cost lots to change later.
old
01-05-2007 11:01:19
I run every thing in my shop on 100amp breaker/service and have never had any problems. I have a 225 buzz box a 6HP compressor lights and all sorts of other smaller stuff and have never had any problems and its ben wired that way for the past 10-15 years. I do have 0 wire running from my well house which is also my power house to the shop and have a breaker box in the shop. I also run my horse barn and other out buildings and well on that same 100amp breaker and it has never triped even when useing things to the max
Richard H.
01-05-2007 10:45:08
My building is about that size and is fed from my house at 60 amps. 225 lincoln, 6.5 air comp, plus lighting and toys. I am a electrician, with that said the only electric heat I use is a 1000 watt heater to keep things above freezing and if I"m in there I heat with propane.
You could even use the panel in the 1st garage as a main lug panel to go to 100 amps to the new bldg. You have to be sure all your conductors and breakers are right.
