Engine degreasers
john
02-19-1998 16:10:29
does anyone know of a good degreaser to
clean heavy sludge in a dissassembled block?
does oven cleaner really work?
Randy
03-07-1998 08:53:44
 Re: engine degreasers in reply to john, 02-19-1998 16:10:29
: does anyone know of a good degreaser to
: clean heavy sludge in a dissassembled block?
: does oven cleaner really work? Hi! The best thing i`ve found to use for a degreaser, or rust remover, and it even frees up froze up parts is Gum Out Carberator cleaner.. It`s a little exspensive, but it works great!! But like the rest, becareful around paint,rubber, plastics, ect.. I use a lot of it!! < Randy >
Dave
02-21-1998 22:22:09
: Re: I use mineral spirits ( the same solvant that is in my parts cleaner tank) and a 2000 psi power washer.
Kevin
02-21-1998 11:13:38
I use simple green or diesel with a wire brush and a putty knife.
Pete Pryor
02-22-1998 21:49:21
 Re: Re: engine degreasers in reply to Kevin, 02-21-1998 11:13:38
: : : does anyone know of a good degreaser to
: : clean heavy sludge in a dissassembled block?
: : does oven cleaner really work?
:Same principal but two other products I've had BETTER luck with:
OIL EATER and Super Clean (Later in purple spray bottle by STP?) I like both of them better than SG. Pete
cw
03-26-1998 20:33:05
 Re: Re: Re: engine degreasers in reply to Pete Pryor, 02-22-1998 21:49:21
: : : : : : does anyone know of a good degreaser to
: : : clean heavy sludge in a dissassembled block?
: : : does oven cleaner really work?
: :Same principal but two other products I've had BETTER luck with:
: OIL EATER and Super Clean (Later in purple spray bottle by STP?) I like both of them better than SG. Pete
Industrial cleaner called WOW.Works super on grease.
Jim
02-20-1998 17:12:30
I heard that oven cleaner works (never tried it myself) but I also heard that it destroys paint and wiring and anything else made of rubber (heard that from someone who did try it!!)
T.K.
03-20-1998 20:58:35
 Re: Re: engine degreasers in reply to Jim, 02-20-1998 17:12:30
: I heard that oven cleaner works (never tried it myself) but I also heard that it destroys paint and wiring and anything else made of rubber (heard that from someone who did try it!!)
Howard
03-04-1998 21:21:37
: My experience is that oven cleaner takes everything but the metal. Also a mixture of household lye and water gives the same result and is much cheaper. Don't let it near paint you want to keep!!!
J.Roberts
04-17-1998 06:12:44
 Re: Re: Re: engine degreasers in reply to Howard, 03-04-1998 21:21:37
I have always used GUNK as a degreaser.Have had good results with it.
Dave Cole
03-11-1998 07:18:48
: : I heard that oven cleaner works (never tried it myself) but I also heard that it destroys paint and wiring and anything else made of rubber (heard that from someone who did try it!!)
: : My experience is that oven cleaner takes everything but the metal. Also a mixture of household lye and water gives the same result and is much cheaper. Don't let it near paint you want to keep!!!
- I've used kerosene, paint thinner, concentrated detergents,
etc. I think the best is kerosene mixed with a commercial
cleaner like 409. Put it in a tank sprayer, spray, soak and hose/pressure blast off.
I've heard that the best thing to do is to get a metal container, fill
it about 1/2 with water, mix in 4 or 5 small cans of Drano (caustic soda)
and heat it up to about 150 degrees with a hotplate or something.
Let the parts soak for a couple hours and presto - completely degreased.
This is the basics for a "hot tank" commonly used by auto rebuild shops.
Good Luck,
Dav
