Rubber Boot on Lower Ball Joint
Jim Becker
04-13-2001 18:42:33
I have a 1996 Chevy Silverado that the rubber boot on the lower ball joint has developed a slight tear in the rubber. Do you know if you can just replace the rubber boot or do I have to buy the entire new ball joint with a new rubber boot? Any info or experience would be greatly appreciated.
Thanks
MarkB
04-14-2001 05:26:25
 Re: Rubber Boot on Lower Ball Joint in reply to Jim Becker, 04-13-2001 18:42:33
If you've got over 100K miles, you'll be changing ball joints before long anyway. If you change the boot, you're halfway there already. In the mean time, keep it greased up.
BTW, the lower ball joints on these pickups require a special press to remove and install them. You can rent it at your auto parts store. Don't try replacing the lower joints without using the press.
John Ne.
04-13-2001 22:20:55
Jim, Sometimes, and only sometimes you can get a new rubber boot from an auto parts store. Go to the dealer and they will try to sell you a whole new ball joint. Try a small repair shop, you might get a usable boot off an old tie rod. Til you get it fixed, keep pumping it full of grease. John
