Tool Talk Discussion Forum
How do I remove a half moon key?
Gwiz
01-04-2007 18:46:31
Anyone have a good trick or procedure for removing a half moon key? I've got it moving slightly with vise grips, but don't seem to be gaining much.
Thanks
James
Gwiz
01-06-2007 10:18:57
 Got it! in reply to Gwiz, 01-04-2007 18:46:31
Wish I had asked before I started. I used a drift punch and didn't damage the key at all. Problem is I buggered it up pretty bad with the vise grips. Lesson Learned.
Thanks
James
MikeCatthemuseum
01-04-2007 22:22:14
 Re: How do I remove a half moon key? in reply to Gwiz, 01-04-2007 18:46:31
As some others have said, give it a tap... but use a brass or aluminum drift instead of a chisel or screwdriver and you might be able to re-use the key.
john cub owner
01-04-2007 20:14:51
I normally use a pair of side cutters at the end to grip and lever up with. I did have one I ended up taking to a machine shop, and after he fought it about 10 minutes hew welded a nut to it for a better grip.
paul
01-05-2007 09:43:40
 Re: How do I remove a half moon key? in reply to john cub owner, 01-04-2007 20:14:51
Yup, sidecutters or nippers.
Last couple have been really bad, ended up slow but good to go after it with s Dreml type cutter & a cutting blade, cut it down the center & folded it inward.
--->Paul
ebbsspeed
01-05-2007 07:13:35
Yup, sidecutters are my tool of choice as well, for the tough ones. Never heard about the "welding a nut to it" trick, but I suppose that would shrink it a bit after cooling, plus give you something to grab on to.
old
01-04-2007 19:46:46
Best way I know is you take a chiesel and hammer and which ever end sticks up you tap it parrel to the shaft that its in. it should slide/pop right out
Gwiz2
01-04-2007 19:13:52
You have to have the other halfmoon connect and it will come out..No problem
Ozlander
01-04-2007 19:05:23
Tap lightly on one end, the other end should pop up.
Ozlander
Ozlander
01-04-2007 19:02:48
Ozlander
RP2
01-04-2007 19:02:04
When they're tight I usually just hose it down with WD-40 and use a flat screwdriver as a chisel to tap it out from one end
