Hi B&D, This is a situation where four or five lights which are controlled by switches at each end of a hallway worked for ten or twenty years and now they don't. To me that rules out the answer that they were wired improperly. Furthermore, nothing electrical has been done to the house in at least a year. I don't wire circuits so that a ground is ever used as a neutral. When I am testing a circuit to locate a problem, however, I often test disconnected hot and neutral (black and white, usually) wires against a proven ground. Sometimes I will use the plumbing if the house is plumbed with steel or copper. Usually I have to fall back on the ground in an extension cord which is plugged into an outlet on a different circuit. I do this so that I will know which wires I will be working with are carrying current. If I put my meter across a black wire and a white wire and it registers a voltage drop of 120 volts, am I completely safe to assume that the black wire is carrying current and the white is the return? I wouldn't bet my life on it. That's why I like to know the status of each individual wire I'll be working with, and that's why I test each against a ground I have separately proven to be good. I'm not talking about doing this every time I perform some uncomplicated bit of maintenance or repair. I'm talking about troubleshooting a problem that's a real head scratcher. I think you'll have to agree that if the brainpower that's available on this forum isn't sufficient to pin down the answer on the first go-round, the situation qualifies as a real puzzler. All the best, Stan
