Briggs and Straton lawnmower engine not getting spark...
EricS
04-13-2001 12:32:42
Hi,
I've got an old Briggs and Straton lawnmower engine that I'm trying to mount onto a bicycle. The engine is probably 20+ years old and has been sitting in my garage for about a fourth of that. Basically what I've done is completely clean it out and it sounds like it wants to run but its not creating a spark from the sparkplug. Any idea what could be wrong?
Thanks,
Eric
Mike
03-25-2004 13:45:47
 Re: Briggs and Straton lawnmower engine not gettin in reply to EricS, 04-13-2001 12:32:42
yeah,I can help ya.buff rust off magnet of flywheel & legs of coil.and if engine was made before 1980 if has points eighter in box on side of engine or under flywheel itself,depending on model.Buff points off flat and smooth and set at 0.020.set coil at 0.06. if no fire replace coil.
Oh yeah check ground wire first.
mick.p
02-24-2002 03:20:14
 Re: Briggs and Straton lawnmower engine not getting spark... in reply to EricS, 04-13-2001 12:32:42
Try checking the airgap between the coil and flywheel,it should be close to the thicknes of a microfish slide.If the airgap is okay,try the points.The corect points gap should be (0.024 in) check with a dealer to make sure.All the above parts mentioned should be free of rust,dust grease or moisture otherwise nothing will work as your spark will go to earth,same principal as a kill switch would work goodluck and always start with basics dont forget to put a new s/plug in first.
Eric Guggisberg
06-17-2003 21:08:28
 Re: Re: Briggs and Straton lawnmower engine not ge in reply to mick.p, 02-24-2002 03:20:14
the float is stuck open in my carburetor, what can i do to fix it???
tito
11-25-2002 03:44:11
 Re: Re: Briggs and Straton lawnmower engine not getting spark... in reply to mick.p, 02-24-2002 03:20:14
my B $ S 8HP motor (at least 20 years old)ran great. however now the flywheel key breaks as soon as the motor starts. i did not hit anything, the only thing i can attribute to it is that i disassembled it to tune it up.i have tripple checked the gap on the points & armature. HELP
Erich
04-17-2001 06:45:39
First replace the plug. If that doesn't work, points and condenser are the next most likely places to look. Back the nut that holds on the flywheel til it is flush with the top of the crankshaft. Get a small prybar and gently pry upward while rapping on the nut with a brass mallet. The condenser is under the aluminum cover. You should also check for a sheared flywheel key at this time. Afer setting the points, put the flywheel back on (don't tighten it all the way yet). Align the magnets on the flywheel with the coil, and turn the flywheel back an forth while holding the end of the plug wire. If you can feel the spark all the way up your arm past the elbow, you have good spark. If you only feel it in your wrist or forearm, it is too weak to run the engine. If it is still weak, It is either the coil, the coil gap, or weak magnets on the flywheel.
bob w.
04-14-2001 11:06:38
if you have no spark from the coil , make sure that the "kill" wire is not grounded out , if still no spark then i think the best repair is to get a new magnetron coil from your b&s dealer these coils eliminate the points and condenser and are fully electrinic , also check your flywheel key that is is not sheared. good luck bob w.
Bama Dee
04-13-2001 13:29:58
Eric, change the spark plug ( I've had plug that looked perfectly good that wouldn't fire. Secondly pull the flywheel and clean the point contacts ( they will corrode if the engine sets up a while. Third change the condencer, they will go bad just from age. Good Luck Dee
