More TIG questions
Rod Mi
04-13-2001 09:36:35
What dues square wave and syncro wave mean? What is preferred? What is the best brand of Tig welders and is there any brand that is easier to set up thanks for the help
T_Bone
04-13-2001 14:34:14
 Re: More TIG questions in reply to Rod Mi, 04-13-2001 09:36:35
Hi Rod, Square wave means the current moves up a given amount accross a given amount then down a given amount making a 1/2 square patteren on a scope. Syncrous waves move up then osulate accross the top then back down or a modifyed square wave.
This controls how the arc preforms.
I haven't used any of the new machines to be able to tell you which is best. What I did when something new came out was to compare the arc stability with a Lincoln Pipeliner as there's nothing that beat the Pipeliner for arc stability.
If it was me I would make them hook up one on each machine and try it as if there's a small difference you'll see right away.
Setup is about the same between any Tig machine. If welding below 150amps then dry torch work well and if above 150amps then wet torch keeps the torch cool while welding but is about $1200 extra cost.
A scratch start Tig torch is the cheapest as it can be added to any DC machine. Amps are adjusted at the machine, the flow meter turns the cover gas on and off, and the Tig torch lead is clamped in the stinger lead. You do not have to have a special machine for Tig welding. I say DC because it has a better arc than AC but AC can also be used. This was a common method for Tig welding during the 70's and 80's. Amp foot and hand contols are nice but not needed. Gas valves are nice but not needed.
T_Bone
Rod MI
04-13-2001 23:00:38
 Re: Re: More TIG questions in reply to T_Bone, 04-13-2001 14:34:14
Thanks T_Bone
